Hazard warning: Anderson PowerPole connectors in shore power wiring
LaRea
Member, Moderator Posts: 7,946 mod
For older Rinker boats with shore power systems, some forum members have reported failures of Anderson PowerPole cable connectors. Anderson makes high-quality products, and failures are rare, but there is a potential fire hazard when they fail. This post is here to raise awareness of the issue, and encourage people to inspect their connectors.
Which boats are affected?
Failures have been reported in Rinker boats from the mid-1990's to late 2000's that have onboard shore power systems.
What is an Anderson PowerPole connector?
Anderson Power (andersonpower.com) makes high-quality cable connectors that Rinker used for shore power wiring (110V AC from shore power or generator). Most appliances that use shore power, such as water heaters, battery chargers and fridges, have an inline connector within 2-3 feet of the appliance. Here's a typical inline connector:
Rinker also used Anderson connectors in outlet boxes, junction boxes and shore power disconnect switches, as well as the main breaker panel. Here's an outlet box with two Anderson connectors (this shows the BACK of the outlet box ... the front has regular 3-prong receptacles):
Not all appliances used PowerPole connectors. Some use normal household plugs that plug into an outlet, but the outlet box might use PowerPole connectors.
Why is this problem dangerous?
Failures are rare, but potentially dangerous because they involve high-voltage wiring. Of the thousands of Rinker boats with Anderson connectors, only a few of our members have reported failures. Most of those involved minor inconveniences, but we had one report of a fire:
How would I know if a connector has failed?
If you are unsure, hire a pro to diagnose the problem. Failures are more likely in wet locations such as the engine room and cockpit. Warning signs:
- An appliance stops working, or works intermittently
- An outlet stops working, or has low voltage
- The red "reverse polarity" light comes on at the main breaker panel
- A connector or outlet feels hot during use
- A connector won't unplug using normal force
How can I inspect for failure?
Unplug the connector and look at the contacts. If won't unplug easily, there might be a problem. If any connectors are partially melted like in this photo, there's definitely a problem.
What should I do if I find a failed PowerPole connector?
Stop using it immediately. In some cases, it might be possible to repair the connector using parts from andersonpower.com. More likely, you'll need to either replace the connector, or eliminate it by splicing the wires. For example, the water heater might be a good candidate for eliminating the connector. (If you DIY, use proper marine-grade connectors -- never wire nuts or solder.)
If your boat has an Anderson PowerPole connector that has failed, please share details here. I had a failure in the shore power disconnect switch, and it caused a "reverse polarity" light. Water heater connectors failed for @raybo3, @Ian and @Rinker310_LI -- probably others too.
Post edited by LaRea on
The point is: inspect your power connectors.
1998 Regal 2100 LSR
If you can't reach the back of the outlet box to unplug them, unscrew the front screws that hold the box to the fiberglass, and pull it out towards you.
Ray
2006 390
Previous 2000 340
On the PowerPole connectors -- I'm guessing we have them because Rinker saved more on labor than they spent on connectors. It's one of the many things Rinker did to keep our boats affordable. What we're learning now (thanks to this forum) is that the connectors have a service life of about 15 years.
