Star Brite or 303 Waterproofing
aero3113
Member Posts: 10,085 ✭✭✭✭✭
Has anyone used both? Is one better than the other? I’ve only used Star Brite and feel it doesn’t bead like it should and doesn’t last as long as it should.
'05 Rinker 360 Fiesta Vee
That's enough to do everything.
Works fine for me. 303 is prob better(?) It seems a lot less caustic than the Starbrite stuff.
The canvas ... you should treat the bimini canvas at least once a year ... in sun scorched areas, maybe twice per year. It protects the fabric ... and it also seals the material so no water leaks through.
Ok. That's good. I'll get some of that as I do have such as seen in my profile pic. Thanks all
I bought some huge vinyl tarps & lay them out on our driveway.
Scrub the canvas with warm water & Simple Green. Rinse it all - let it dry.
Foam roller & 4" paint brush (for edges/zippers) to apply waterproofer.
As LaRea said - stuff is like greased lighting on your shoes till it dries.
Luckily mine is still holding up. I think when the time comes to have a new one made, I would use the same.
https://rinkerboats.vanillacommunities.com/discussion/11405/ameritex-lack-of-customer-service
I got really lucky last fall and found a guy at my marina with a 2019 370EX. I borrowed his canvas over the winter and had a local canvas guy copy it. Ended up being cheaper than Ameritex would have been and I was able to select any color I wanted (Ameritex only allows you to choose the colors Rinker offered).
