Mercruiser Oil Filters
13»
  • YYZRCYYZRC Member Posts: 5,517 ✭✭✭✭✭
    Are you guys sucking from the dipstick or from the drain hose (if equipped)?
  • aero3113aero3113 Member Posts: 9,990 ✭✭✭✭✭
    I suck from the dipstick. I always wonder how far down the tube goes and how much oil is left behind.
    I tried both ways and got about 1/3 quart more from the pan drain when I did the oil change this spring. Lots of variables tho so who knows.
  • Dream_InnDream_Inn Member, Moderator Posts: 7,960 mod
    I do the drain pan.  It’s gotta get more than the stick.
    edited October 2022
    I used the dipstick to drain the oil yesterday and only pulled out just under 3 litres per engine, same as last year. A mechanic said that's normal but the capacity is 4.25L so leaving approx 1 L of old oil in engine.
    edited October 2022
    I have never gotten more than 3.5L out.  I always measure and add the same amount back.
    @YYZRC, I went online after posting and found this chart. I corrected my post
    Genuine Mercury & Mercruiser parts. Mercruiser Gas Engine Oil Capacity Chart
    Do you warm the engine up before changing the oil @grahamu ?
    Yes to 145Fand then sit for 10 mins to let oil drain into pan. I also punch a hole in the filter.
    Anyone ever have an issue getting their oil filter off? A friend of mine is having a heck of a time getting his oil filter off. He is ready to replace the plate that it sits on. Everything that I have told him to try hasn’t worked.
    Maybe hammer a long rod or screwdriver through both sides and use it as handles to spin off.
    I had this issue once, years ago.  I ended up using the hammer and screwdriver method.  I put edge of screwdriver at base of filter and tapped it with hammer into the CCW direction. It finally started to budge.
    +3 for hammer and screwdriver method.  That happened to me on both filters on my boat when I first bought it.  I assume the last person to change the oil didn't lubricate the o ring.
    Yep big long screwdriver as well.
    Oil filter pliers will work too, They are messy & will tear it all up. But generally work.
    For boat I always take the band type filter wrench & the filter pliers for back-up.
    I’d use a little heat to warm up that gasket. Not too much!
  • IanIan Member Posts: 3,073 ✭✭✭✭✭
    Aqua_Aura said:
    Loving my Volvo more and more, thanks guys. 😂😋
    Friend has the Volvo and seems he has a similar pin issue with a drip from up there.
