Engine misfires at 4k rpm
2»
    Definitely an ECM-555.  I can't find any info on the version 5 firmware compatibility.  A quick call to Rinda may be useful.  They may also have version 6 upgrade kits available.
    https://www.rinda.com/rindashop/shop/update/94056
    FYI, these tools are more than just simple code readers.  They allow for several PCM test functions to aid in troubleshooting.  See the manual in the link attached for detailed description of the functionality.
    https://www.rinda.com/acro/merc_manual_v6.pdf
    2019 MTX20 Extreme
    edited March 2023
    @Ian mentioned this product recently:  the 555 Scan from ODB Diagnostics.  I haven't used it, but seems to offer the same features as the Rinda for a very affordable $300.  You'd need a laptop or tablet computer to run it.
    Your Merc 350 Mag has the ECM 555 module, so it should be compatible.
    https://obd2allinone.com/555scan.asp
    Decided to take the plunge and ordered today. We’ll see what I get to see!
