transom door latch
Does anyone know where to get a transom door latch with the same hole locations?  1.5 x 1.25.    2003  312
Thanks
    edited April 2023
    There is a few sizes but here is the link. Just measure what you have currently.
    https://www.westmarine.com/perko-chromed-bronze-barrel-bolt-P0424608.html
  • toolmaker312toolmaker312 Member Posts: 130 ✭✭
    Thanks, It seems they are all the wrong bolt pattern or are not showing the dimensions
    edited April 2023
    Not the same, Thanks just the same
    I have replaced mine a couple of times and never even thought to check- they just fit!
  • GrahamuGrahamu Member Posts: 923 ✭✭✭
    Is this the one?
    OK, I like what you did here...how about instead of a hole put a slot open at the top. That slot could be v shaped so as you raise the engine hatch the door would just eventually open vs break the  dang latch? Is this post good for patten?
    edited April 2023
    Go ahead @rasbury just remember to shorten the bolt or reposition it so it will release.
    @rasbury, by bolt I meant the sliding latch. not sure how much to shorten it. I think the door will start to rattle again with that modification
    Nah @Grahamu I'm sure I can fix that!
    @rasbury, I checked mine to day and the vertical slot would not work on my 342
    If yours is like the picture you posted I think it would! Icwas actually kidding when I suggested it but, it would work!
    edited April 2023
    @rasbury you need @j3ff to 3D print something like this (set the angle of the slot to the angle that your hatch opens at, I just ballparked this at around 25 degrees).
    Obviously the bolt cannot extend beyond the plastic disc into the fiberglass hatch.
    Mine would be almost horizontal to the right and I would have to push the door open to avoid the engine hatch hitting it
    We make it adjustable, also a piece of rubber behind it that also covers the slot so it does not rattle....I wonder how many people would buy one? I've broken at least two of them....I think I have a Lowes version on there now...
  • FormulabenFormulaben Confirm Email, Member Posts: 238 ✭✭✭
    edited June 2024
    I'm looking at a completely different door with an internal latch for a fall project...something like this maybe:
    https://www.greatlakesskipper.com/chaparral-boat-transom-gate-15-3-8-x-18-3-4-inch-stainless-steel
    I dlthink I've broken mine 3x? I havexa steel one in there now- and yes it looks like crap!
    I ended up buying one from Menards for parts. I inserted the sliding piece after I shortened it. It is a little thinner but that helps with alignment.  I had to bend back my hinges twice now Thanks
    I'm going to break down and get a new one- and bend my hinges back..which I've been afraid to do- but the snap to hold the door open no longer lines up so a bot of a pain- I figured they would break...
  • echandler1971echandler1971 Member Posts: 249 ✭✭✭
    I transitioned my metal slider into a wood dowel slider. Now when I’m an idiot and open the engine bay with the door latched, the dowel just snaps. I have a bag of replacements ready to go.
    Dan of Steel
    '05 Rinker 360 Fiesta Vee
    So I had an idea, on another thread, for that latch to have an arc it can travel and not break- no royalties yet...
    I took my door off and brought it home and mounted it inside the shed doorway. I measured where it was and then bent up the amount I needed
    So what did you do for a ",nob", something to grab to work it back and forth? I've tried a couple of things that just did not work out! I will say, the one now I have not managed to break. Did I just say that?
    I bought a similar latch that was for a garage door or gate or something. I used that shaft only that already  had a knob. I use the original housing for that shaft and. I modified the length a little bit with a pedestal grinder. I can send you a picture next time I'm out there maybe 4th of July
    I did what you did @toolmaker312 bit it is rusting...so I'd like to replace it, 50 bucks is a pretty cheap fix on a boat huh?
    I used a screw with a hex head that had a decent shank and made of shiny silver metal. I made up like 5 of them cuz I’m an idiot often. Just ask my wife.
    Dan of Steel
    the slider is the only thing that is new
