Fuel pump not having any power
apdcop
Member Posts: 23 ✭
I have a 2002 mercruiser 5.7 350 fuel pump on the starboard not turning on when I turn the key on. (not priming). I have replaced the fuel pump already and swapped the relays fro the port engine. It does not appear to be getting power the the key is on.
When I turn the key on on the port engine you can hear the fuel pump turn on for about 3 seconds
Any advice is appreciated. Even better, if someone has a wiring digram I might be able to figure it out.
Thanks in advance
Thanks in advance
rear port side of motor.
