Fuel pump not having any power
apdcopapdcop Member Posts: 23
I have a 2002 mercruiser 5.7 350 fuel pump on the starboard not turning on when I turn the key on. (not priming). I have replaced the fuel pump already and swapped the relays fro the port engine.  It does not appear to be getting power the the key is on.
When I turn the key on on the port engine you can hear the fuel pump turn on for about 3 seconds
Any advice is appreciated.  Even better, if someone has a wiring digram I might be able to figure it out.
Thanks in advance
  • aero3113aero3113 Member Posts: 9,863 ✭✭✭✭✭
    Does the engine crank? If not, there’s a small 10 amp fuse that’s mounted on top of the engine near the port riser. Check that.
  • Rich_Rich_ Member Posts: 339 ✭✭✭
    I’m going with the fuse as well. I was delivering a boat when one engine cut out. Quick diagnosis was fuel pump quit because no pump buzz when ignition on. Limped to a harbor, tied up and confirmed no pump. Next day in daylight continued delivery on one engine and helped owner swap a fuel pump, but still no buzz. Fuse was good but turned out the fuse holder connection was too wide for good contact. Wish I thought of that at the time instead of the slow one engine ride
    Check the fuse like they mention before, it just happen to me last month and the fuse holder was burn.
  • apdcopapdcop Member Posts: 23
    I appreciate the feed back.  I will go out to the boat on Monday and see if it is the fuse.  Hopefully it is!  Thank you again and be safe!
  • J3ffJ3ff Member Posts: 4,232 ✭✭✭✭✭
    Same thing happened to me, replaced the fuse about a year ago and nothing has happened since.
  • rasburyrasbury Member Posts: 8,965 ✭✭✭✭✭
    Where is this fuse?
    rear port side of motor.
    Hmmm.how do you check it? Might be my problem too.
    It's just a cap... there's three fuses in there.. get in there and pull it apart, you'll see
  • PickleRickPickleRick Member Posts: 4,371 ✭✭✭✭✭
    If you don't drop at least one fuse in the bilge and have to fish it out from under the oil pan... you're not checking them properly
    I did that this weekend...one starter bolt (they really get some momentum) and then the nut that the hot wires go on. But in my defense I had to put the starter on 2x..  don't ask.
    This was the cause of my fuel pump damages
    Oh crapola! I went to my boat today but forgot the dang key..tomorrow..
    @rasbury you should hide a spare somewhere on the boat.
  • raybo3raybo3 Administrator Posts: 5,615 admin
    @rasbury Not sure where you keep your boat. I am at a yacht club. I keep my keys right in the ignition. Never have to worry about forgetting them. I also keep spares in the blender compartment.......... Just say'n
    If you really want to detour potential thieves hang a Bayliner sticker over the rinker emblems.    Stealing a Bayliner is like stealing from Ross, it's cheaper just to pay for it.
    Well..I lost my spare, it is on the boat somewhere...I usually keep it in my truck but...
    Thanks @raybo3 - def need a boat to borrow when up there!!
    @J3ff I checked those fuses...they looked fine. It is not pulling fuel.  I'll see how much one is...I'm sure it does not cost more than a couple of hours of shop time...
