BRAVO 3 LOW LUBE ALARM
After putting my 2000 Bravo 3 outdrive on and off several times during the week, I leaked out enough lube to drop the level in the resivoir so the alarm (steady ringing) went off when I went to plane off. I filled the lube back up, but the alarm continues to sound. I have oil pressure (40lbs at idle) and the engine is cold. I disconnected one lead to the sensor, but the alarm still sounds. Should I jump the 2 wires to see if it quiets the alarm there by confirming a bad sensor, or could this damage something?
not sure if they use normally open or closed switches
full of sludge
No clue what the deal is.
I think I tried this before and it still went off, but will re-verify this on Saturday...
Assuming that it's still going off when wires disconnected.. where does that leave us?
I dont know what to think.
I let it sit for a while, came back, turned the key to the run position and sure enough here was the alarm again.
I also put some foam tape over the hole for the sound and then electrical taped around that. It's still loud enough to hear but not so much so that you'll lose your hearing.
For today it's disconnected.
I dont know what else it could be aside from corrosion or a bad ECU?
To date I have:
- disconnected the wires from the lube sensor, everyone says this should stop the alarm, it did not.
- replaced the entire resi. with a new one, sensor, and wires, still happening.
- I've looked for broken wires, reseated the main connectors, looked for a bad fuse...
Boat starts and runs fine.
