If not a spun hub, then what?
TickledPink
Member Posts: 130 ✭✭
So, as you know, I'm still learning about all this boat stuff. I haven't picked your brains for a while but I definitely need some advice now.
I have high revs but low speed. Researching this ,I figured it's a spun hub. OK, cheap enough and easy to replace.
But now I've read that the Bravo 3 has no hub, so what is damaged? I can see this being expensive 😳
3500 means you're not getting enough rpms or power.
As @YYZRC mentioned you could just need a good tune up.
Before pulling the engine get it to normal running temperature and pull all the plugs to do a compression test.
Keep the plugs labeled as to which cylinder each one came out off for a visual inspection, plug color tells a lot about an engines running condition.
With all that in mind, he wants to pull the engine out to see if there's anything else that he can't see,
All in all its turned out to be a money pit but I'd rather get it all fixed up than get rid of it.
A part of the skeg is broken off too but that was done after I bought it. I don't recall hitting any rocks or anything but it's a weld job.
Before the skeg break.
I would replace the cap/rotor/plugs/wires as a first step. Couple of hours of relatively easy work not terribly costly in boat terms at about 500 quid.
I wouldn't worry about the skeg, it is not an urgent repair by any stretch. At only 8mph you aren't going fast enough to derive any benefit from it!
(BTW the blower needs another section of 4" duct that extends down into the bilge. You want the blower pulling air from the lowest point, which is where gas fumes would end up.)
I'd like to get the Hill 4x4. Not sure I can get it over here but I'll do some googling.
