Victron Lithium House Bank
YYZRC
Member Posts: 5,364 ✭✭✭✭✭
I currently have 3 AGM Group 31s that are toast. They are about 5 years old so not unexpected.
Has anyone switched to a lithium house bank? If so, what are you running for batteries/charging?
Post edited by YYZRC on
You get more useable power over just using a 12v battery. Might be an option for now until you want to make a jump to lithium in the future.
If you don’t go with a Victron setup, you could use a DC:DC charger from the isolator to the battery.
I reached out to MSI to get his opinion on the best setup. https://marinesolar.com/ - this is where I got my inverter setup from.
Victron Multiplus II 12-3000 inverter/charger
Victron 200ah Lithium battery
Victron BMS
Victron Smart Shunt
I disabled/removed the starboard shore power inlets and used that breaker for the inverter setup. I originally installed the inverter in the cabinet below the breaker panel (where the central vac was located) but moved it to the bow for better weight distribution.
For starting batteries, lithium doesn’t make sense because of the cost differential but otherwise performs well.
you will need to move the lithium battery out the engine bay, because lithium battery doesn't like too cold or too much heat during charging process.
https://gilwellbear.wordpress.com/2023/02/01/lithium-ion-batteries-on-boats-1q23-update/
The author is a well-known authority on boat electrical systems. It's a long technical article that discusses system design, wiring, cost, insurability, and a lot more. He strongly cautions against the idea of just "dropping in" a set of lithium batteries.
His bottom line is: "For those WITHOUT advanced electrical technical skills, then my advice is, wait another 3 – 5 years while this stuff works itself out via new and updated standards, new standards-compliant equipment and new system designs. Why? Because the current environment does have the ability to disappoint."
I can summarize his commentary (calling it an article is overly generous) pretty succinctly: "you can buy 6 golf cart batteries for $650 at Sam's Club, or you can spend more".
The author ultimately conveys that at the time of posting the commentary (late 2022), lithium is significantly more expensive to implement vs legacy battery technologies and with a much longer payback period. The author quotes lithium costs of $4000 for 400ah (prices from December 2022). It would be interesting to see the author present his views with current market pricing and with total system weight as a consideration. It's not hard to find 400ah lithium for less than $2000 today from reputable suppliers.
It would also be interesting to consider the resale value implications of a boat with a proper lithium setup vs golf cart batteries; the author does not contemplate this, but if you've taught us one thing @La_Rea its that a clean and modern/safe electrical setup is dreamy.
In my opinion, as it stands, his commentary could be a relevant for a cost-conscious trawler owner, but it doesn't align with my needs as an express cruiser owner that is willing to pay a reasonable premium for performance/longevity/weight savings.
And it's definitely worth checking the insurance policy before making a conversion.
For 1k I can get rid of approximately 300-600lbs of unnecessary weight on your boat.
You'll lose all your food. Beer will be replaced with rum and the admiral/mother-in-law and kids along with all their clothes/toys/baggage will be left at the dock.
There's a chance you'll be sleeping on the boat long term once I'm done with the weight reduction service so check your live board marina policy first.
I'm currently paying about $160 for a Group 31 lead acid battery that will usually last me 4-5 seasons (at least).
If I switched to a Lithium equivalent, it'd cost me about $1000 - which is about 6X the cost. Will that Lithium battery last me 24-30 years?
As for weight, LA is 59lbs and the LiFePO4 is 31lbs. Half the weight - or about 4 gallons of water. I can lose that weight just by regularly emptying the holding tank from all my friends rum and cokes that they deposit into the head. :-)
I just can't justify it at this time, but maybe in time things will change. I look forward to all you early adopters to keep us posted about your experiences.
@kordo Marine Solar Innovations boat show pricing is $1299 for a Victron 200ah lithium and $1799 for a Victron 330ah lithium. They offer a discount for purchasing two or more.
To get almost the same ah from AGM you'd need 3 batteries (about $1200), so switching to lithium would cost about 30% more.
https://rinkerboats.vanillacommunities.com/discussion/comment/174193#Comment_174193
Here's my planned setup. Slightly more expensive than going with non-Victron batteries but super simple to implement. This setup allows me to keep my existing Promautic 1240p charger and also allows me to charge the lithium house batteries via the alternator.
Existing Components
ProNautic 1240p Charger
Victron ArgoFET Isolator
Victron SmartShunt
New Components
2 Victron Lithium 330ah
Victron Smart BMS 12/200 (Ignition Protected)
Victron M8 Connectors
System diagram is as follows; only a small amount of new cable required. Most important is to split the alternator from the existing charging circuit.
