Boat only receives ~70 volts on shore power
Spyderweb
Member Posts: 959 ✭✭✭
Went up to boat yesterday to begin annual buffing (boat on land). Hooked up shore power to port side receptacle. After figuring out all the right switches to set (it’s a long time between boating seasons in northern NY) the gauge on the electric panel finally showed power, but only getting about 70 volts. Double checked connections but found no obvious problems. Thought it might be marina’s problem.
Switched my connection to starboard side and got full 120 volts. 98% of time I use starboard, but I did use port a couple times last year, and I know it worked fine. Don’t ever recall anyone having a problem like this. Any ideas?
https://rinkerboats.vanillacommunities.com/discussion/13379/hazard-warning-anderson-powerpole-connectors-in-shore-power-wiring
Ray
2006 390
Previous 2000 340
Anyway, was disappointed I couldn't get any further and put it all back together. Just because I did a lot of wiggling of it to get it that far out, I decided to plug shorepower back in and check results. Voila! I'm back to 120 volts. Will leave it alone for now.
When an electrical problem disappears after you move the wires, that's a danger sign -- especially with high-voltage wiring. I'd pull those connectors apart for a close inspection. Before you disconnect them, see if they feel warm.
If it was me, I'd stop using that circuit until I found the problem.
@Spyderweb to separate those Molex connectors you simultaneously press the middle clear plastic tab on both sides and wiggle side to side while pulling apart. They are very stiff.
If you get in your bilge and look up into that side of the gunwale area, you will likely be able to cut a zip tie to release more wire. The 330/340 and 350/360 use the same wiring harness so there is lots of extra wire to allow for different hull lengths/configurations.
Separately, I think the only place I've found a PowerPole connector on the 330 or 350 was at the water heater. Everything else are these Molex connectors.
My next step was to go into bilge and look for options to lengthen wire, just didn't't have time to dig deeper. Will look further once launched.
If it won't unplug, is hard wiring still best option?
Quarter-turn receptacles are a relatively recent thing ... yeah, probably replaced by PO.
@YYZRC - what year would you guess Rinker started using Molex connectors?
@LaRea both my Rinkers were 2008 models so I couldn't say for sure but my guess would be that they deployed the Molex with the last "new" generation of express cruisers which would start with the 2007 350EC followed by the 2008 330EC.
https://www.greatlakesskipper.com/rinker-boat-shore-power-harness-2230215-breaker-10-awg-30a
The link above is probably the exact setup we have in our boats.
