Meet the new La Rea!
11516171921
    Gas consumption?? LOL
  • LaReaLaRea Member, Moderator Posts: 7,844 mod
    Figured you guys might ask!   :D  I've bought 5473 gallons of diesel.
    I've burned around 650 gallons in the genny.  At my 800 rpm happy speed, I'm usually making 7.5 knots at 2.3 mpg.  On plane, it's 23 knots at 0.5 mpg.  And of course, we've spent a fair amount of time idling at zero speed in locks or waiting for bridge openings.
    Wow awesome! You are getting there. Looks like you went east in to TN and then back? I'm sure it's out there and I missed it, but was that to check out a spot or some friends? Had to have been a couple days each way in the rivers. How many gallons burned? :)
  • FormulabenFormulaben Confirm Email, Member Posts: 161 ✭✭
    You hit the lucky jackpot!! ;)    ...but dang, I have some catching up to do!!  :o
    So with happy speed 800rpm (My D6's are similar), how are you making sure to work the engines some? I've read many places that our Volvo's are designed to run with a good load so if we are going to do long term idling we need to periodically get on plane. Something like 30 min on plane for every 4 hours off plane/under load. I dont recall. Are you making sure to work them too?
  • aero3113aero3113 Member Posts: 9,288 ✭✭✭✭✭
    Very cool @LaRea ! ⚓️
    Oh I'm not bashful with the throttles!  We've done a fair amount of time on plane.  We crossed the Gulf from Carabelle to Clearwater on plane (150 miles) and yesterday from Marco Island to Key West (90 miles).  But even going long days at idle speed, the engines never complain.
    @Liberty44140 - terrific side trip to Chattanooga.  The Tennessee River Gorge is spectacular.  My brother and his wife came to see us ... stayed on the boat and cruised the final 20 miles up the Gorge.  It's called the "Grand Canyon of the East" for good reason.
    @J3ff -- Key West is your neighborhood, right?
    Very cool on the side trip to Chattanooga! Thanks for sharing.
    Good info on idle vs plane. There are a lot of days where the admiral wants to just cruise at 800 - 1000rpm and all the "diesels NEED to be run with a load" posts out there have made me wonder.
    Trip looks awesome!!!! Nice run from Marco to KW - so freaking cool!
    Yesterday's adventure: repairing the pop-up TV stand in the salon.  A cabinet hides the TV when we're not using it.  The lift motors decided to stop working, and unfortunately the TV was down making it impossible to reach anything.  I had to remove the cabinet, cut an access hole in the back, and remove some bolts to get the TV out.  Good healthy fun!
    The worst problems are the ones that spontaneously self-heal.  That's what happened here ... it just started working.  If it happens again, I'll know what to do.
  • Dream_InnDream_Inn Member, Moderator Posts: 7,719 mod
    I bet you cleaned those wires up in the cabinet before you put it back together too. :smile:
  • johnny44johnny44 Confirm Email, Member Posts: 115 ✭✭
    @LaRea - No digital business card app??? Doing it the old fashioned way?
    Sold - 2008 350 EC -- Greenwich Bay, Rhode Island
    Yeah, trading boat cards is a Looper thing.  We have met a ton of people.  You're right, I should have bought a card scanner!
    @Dream_Inn - I also found and removed the original Simrad rate compass, which will get sold on eBay.  I knew there had to be one on the boat somewhere!
  • Lake_BumLake_Bum Member Posts: 1,021 ✭✭✭✭
    Just wanted to say, we enjoy your progress pictures!  Rinker or not.....boats are boats  B)
  • YYZRCYYZRC Member Posts: 5,260 ✭✭✭✭✭
    Update on the swim platform hydraulics?
    Platform still won't lock in position, and I'm still using the same chocks to hold it up for normal cruising.  I'm guessing the pawls that engage the lock bar are worn or broken.  I'll need a yard to take apart the whole assembly and fabricate new pawls.  That'll probably take a couple weeks, so I'm not looking forward to being out of the water that long.
  • captkevincaptkevin Member Posts: 336 ✭✭
    Congratulations on figuring it out
  • Rich_Rich_ Member Posts: 235 ✭✭✭
    Guy who should never operate a boat is a 63? Bertram
    In my defense, that boat is a Riviera -- not a Maritimo!
    I’m going with Bertram
    Right you are @Rich_ ... the Riviera has a window in the side of the hull.
  • mattiemattie Member Posts: 1,305 ✭✭✭✭
    You guys might remember my post from October when I installed a VHF antenna switch.  After that, I started getting some weird interference.......
    Not at the same level....
    But I once wrapped some Taco Bell burritos & placed them on my engine intake to warm them.
    Needless to say - none of the engine guages were fond of that idea. Talk about interference.
    edited March 15
    This weekend I got started on the repairs to the hydraulic swim platform.  Hauled the boat at a DIY yard in Fort Pierce called Cr@cker Boy, and removed the platform from the lift.
    After a lot of head-scratching, I figured out how to remove the lock mechanisms.  They are both completely trashed.  Best guess -- a previous owner must have strapped a heavy jet-ski onto the swim platform and gone out in some rough seas.  As I suspected, it sheared off the teeth on the ratchet pawls.  It also bent the ratchet bars and frames.  Then they did a crap repair that didn't fix the problem.
    I found a talented and experienced metal-worker who is going to rebuild them for me.  It won't be easy or cheap, but I'm glad to finally have a solution lined up.
  • TonyG13TonyG13 Member Posts: 1,355 ✭✭✭✭
    How many people did it take to get the platform off and down to the ground? I know you and Diane are in good shape but that has to weigh a bunch!
    edited March 15
    @TonyG13 -- Four nuts that came off easily, and the yard forklift!  The whole thing took about 15 minutes.  Honestly, I budgeted two full days to get those lock mechanisms out.  It took about three hours.
    I was reading a bit about the yard and the DIY aspect. Interesting and fascinating. How do they handle scheduling and wait/haul times? Do they charge storage by the day/week/month? And I noticed no liveaboards, so are you living the high life in some fancy schmancy condo while working on LaRea? :-)
