1…121122124126127…146
    You can see how worn the electrode is, it wasn't burning correctly for a while.
    3 looks hardly used.
  • Rich_Rich_ Member Posts: 366 ✭✭✭
    Still have to wax the Grady but getting closer. One 15 Whaler is painted.
  • FormulabenFormulaben Confirm Email, Member Posts: 232 ✭✭✭
    Is anyone else see this website kinda jacked up today. Content is all there for me, but showing every topic unread/new and also certain text/images are corrupted.
    Seems normal to me
  • captkevincaptkevin Member Posts: 603 ✭✭✭
    Looks good to me
    edited April 2025
    @raybo3 I cleared the cache and all that...parts of the forum were completely unreadable last night. Better today but still glitchy in lots of areas for me. Never seen this before.
  • johnny44johnny44 Confirm Email, Member Posts: 137 ✭✭✭
    I am seeing it the same way with same issues as Formulaben.
    Former Boat: 2008 350 EC
    Greenwich Bay, Rhode Island
  • aero3113aero3113 Member Posts: 10,021 ✭✭✭✭✭
    I received the drain fitting assembly today. Hopefully it will warm back up outside so I can install it!
  • raybo3raybo3 Administrator Posts: 5,621 admin
    @Formulaben and @johnny44 I looked into your accounts and could not find anything wrong. Give it a couple of days and see what happens. If it continues let me know and I will try to figure something out.
    It was messed up for me until about an hour ago. Now a ok
  • YYZRCYYZRC Member Posts: 5,540 ✭✭✭✭✭
    Now all good
    Yep, I'm all good now too.
    Way to go @raybo3. Thanks for all you do for us
    edited April 2025
    Better now...sorry for the thread hijack! Now back to your regularly scheduled boat upgrades! :wink:
    @Pat310 thank you
  • rasburyrasbury Member Posts: 9,005 ✭✭✭✭✭
    @captkevin it’s an easy project. ⚓️
    What,  changing the filler cap? I'll give you that one..
    Guess I'll get some clean up going...just said bye bye to my job.
    Sorry to hear Rasbuy
    Is this a good thing or a bad thing?
    I descaled both engines. Port had a lot of brown come out, starboard was pretty clean. I had it drain into the bilge then into a bucket outside so I don’t kill the grass. There was a hose that was crunchy on the port side, I took it off and cleaned it out, a ton of scale! I also replaced the drain tube. You can see where it was leaking. Now I need to get her in the water and go for a good run to blow everything out!
    With the new oil pressure senders in they’re reading about 45 at idle where the old ones were reading 40. If I rev the engines slightly they would climb to about 60. I’ll have to see what they read when I can cruise and get the engines at running temp.
    I had power on the other day and couldn’t get my wired carbon monoxide detector to reset, it kept beeping. It’s original to the boat so it needed to be replaced. I also use a battery powered one in the cabin as the primary. Original says replace by June 2010 and looks like it was manufactured August 2nd 2007. New one says replace 60 months after retail sale. They had it wired with 2 sets of butt splices, I just pulled on the wires and there was extra slack to be able to use one set. I used @Aqua_Aura ‘s heat shrink connectors 👍🏻.
    edited April 2025
    I also noticed that the starboard side drain tube was seeping like the port side was, have that on order.
    Where did you buy from @aero3113 ?
    Balmy. Didn’t get over 36 here today, was in Pittsfield MA around lunchtime and it was snowing.
    I bought it from a seller on eBay. I just checked and looks like they no longer have them in stock. I believe the new version is flush mounted and you would need to cut the square to fit.
    @YYZRC I just found this seller who looks like they have a bunch of stock. Expensive, but at least you can replace it. I got mine for $51.10.
    https://www.ebay.com/itm/205403514103?mkcid=16&mkevt=1&mkrid=711-127632-2357-0&ssspo=4tsfDw3AQAO&sssrc=4429486&ssuid=jb9VSTJCQVS&var=&widget_ver=artemis&media=COPY
    Stripped and painted the arch bases the best I could. The paint was heavily cracked and bad pitting on the face. I’m going to wet sand the sides and give it one more coat in a few days.
    NICE!
