1…122123125127128…146
    edited April 2025
    I just used some of my connectors as well to wire an electric lift to our clubs tug boat. It now has an up down switch to lift the center console to access the lower engine room area.
    I spent a few hours rebuilding our guest head today. The waste line below the toilet was creased in half and would clog very easily, bad install at some point. Everything that is a maintenance part in that system is now replaced including all new waste line for that toilet.
    I painted the lazarette lids gas shocks black again after sanding the surface rust and reinstalled with new stainless screws and nuts.
    Found the cause of the hatch leak and fixed that over our bed in the v berth.
    Yesterday we dropped off all the fly bridge seating and helm seat from the fly bridge and are having it all reupholstered at a local shop. We are getting two toned light tan and light sand color.
    I have a few more maintenance items to get done like oil changes on the engines and also I need to finish wiring my cockpit and fly bridge speakers to the stereo and also the light controller.
    We have our first club event in a couple weeks so I need to be all ready 😊.
  • aero3113aero3113 Member Posts: 10,021 ✭✭✭✭✭
    I replaced cool fuel filters this morning. Port was a little dirtier than starboard but not bad. The little tab on the lower screen for the port side broke off when I tried to remove it, a 90 degree pick helped remove it after. Painted drives and replaced anodes also.
    Port
    Starboard
    Just when I thought I was coming to an end with spring prep I just saw my Starboard circulating pump had a slight weep at the top weep hole. Not enough for a drip but it would come back when I dried it off. The descaling probably added to this but this circulating pump always looked suspicious to me. Glad I have a reason to replace it now. I’m going to do the port side as well. Has anyone done this job? Looks pretty straightforward. Hopefully the bolts don’t give me an issue.
    edited April 2025
    Now that I think about it, the starboard engine would squeak when I started it every once in a while last season. I always thought it was the belt but must’ve been the circulating pump shaft bearing starting to fail. I spent about 45 minutes heating the bolts with a torch and putting some mouse milk on them, this should help when go to remove them.
    I just ordered the flybridge flooring from Plasdeck out of Ohio. Great company to deal with, this is the same thing we did in the cockpit last year. I'm going to have about 15k just in the flybridge from the new canvas(2024), flooring and upholstery. I'll post some pictures end of next month when it's done.
    edited April 2025
    Moved it! Unloading the storage shed but keeping mine under cover for now to prep, no room outside and didn’t need snow on it. Seriously….
  • GMSLITHOGMSLITHO Member Posts: 1,626 ✭✭✭✭
    Nothing
  • YYZRCYYZRC Member Posts: 5,540 ✭✭✭✭✭
    @aero3113 I replaced the circ pump in a Volvo 5.7 and it was a straight forward task. It was originally a saltwater boat and the pump lasted 18 years.
    edited April 2025
    Yesterday I ripped the old poop tank out. Fun stuff.
    Changed the oil in both drives. No water in the old oil and no metal filings on the drain plugs so all good!
    Also installed a new pickup for the cockpit AC.
    Did you replace the waste take or just take out the old one? What was wrong with the old one?
    I was worried taking out my waste lines and vacuflush tank to clean and replaced the lines but it was actually not bad. We stay on top of flushing out and treating the system.
    Old tank had collapsed (previous owner) which caused a crack at the outlet fitting. I had it repaired but every time I had it pumped out I had to go into the bilge and remove the tank saver so the tank wouldn’t collapse again.
    I bought a new tank on GLS, same as what came with the boat.
    I got the Starboard side Circulating Pump off today (it was definitely original to the boat). I had to hammer on a 13mm to one of the bolts, I guess the corrosion through the years shrunk it 😂. All four bolts came out easy, I’m sure the two days of Aero Kroil and heat helped. I have new bolts on order. It’s crazy how dirty everything is behind there. I’m replacing the large hose assembly to the thermostat as well, I didn’t like how the hoses looked. @YYZRC did you use any sealant on the gaskets? I had a grease spot on the port cover that I couldn’t get off for a long time. I tried some Zep heavy duty and it came right off!
    I’m not even attempting to get the 4 bolts out to remove the pulley on the pump. The threads on the back side are very corroded. I was able to find a seller on eBay that had 2 new Quicksilver pulleys in the box for $40.
    @aero3113 I cleaned the mounting points on the block well and bolted it up with the supplied gaskets. Nothing extra.
    Thinking back - the cheapest price I could find for the circ pump was at a distributor in the US and they wouldn't ship to Canada. I was in Virginia for training so I had the pump shipped to my hotel and I flew back with it in my carry-on baggage. The TSA guy was a bit confused to say the least.
    Thanks @YYZRC I’m surprised no sealant on the bolt threads, they go right into the water jacket.
    You should’ve told TSA it’s a spare part for the plane!
    I was just googling circulating pumps because I have nothing better to do than think about the boat 😂. I just realized I ordered the wrong pumps!! The ones I ordered have a bypass hole that line up with a hole in the block. The ones I need don’t have that hole. I’ll have to return and reorder. Strange because I ordered using my engine serial numbers.
    Nice @Rich_ !! ⚓️
    Here’s a pic if anyone was wondering what I’m talking about with the Circulating Pumps. I read you can use the one with the extra hole on a block without the hole, but I would rather get the correct one. I feel it could be a leak point if the gasket decides to fail.
  • captkevincaptkevin Member Posts: 603 ✭✭✭
    Interesting - never knew that
    So it seems like the circulating pump with the bypass hole is the correct pump. I did a ton of research and even went to a well known Marine parts store and asked a ton of questions. Non of their research could come up with the non bypass pumps for my engines. They also said it looks like my old pumps are for 4.3 V6 engines. I’m going to use what I bought. I always felt my engines ran a little hotter than normal (around 175 when I have 160 deg. Thermostats) curious if I’m going to notice a difference in running temp. They said it’s possible that my old pumps could be different internally and only used for V6 engines 🤷🏻‍♂️.
    edited April 2025
    Isn’t the purpose of the bypass to allow the engine to warm up more uniformly? If that’s true, it shouldn’t make a difference at operating temps.
    edited April 2025
    @YYZRC My thinking is the impeller could be bigger or have more veins.
    Maybe worth testing your thermostats in a pot of hot water. I replaced my thermostats around the same time as you did and my boat runs at 160 without wavering. I am also raw water cooled and essentially the same motors.
    I replaced my thermostats beginning of last season, whole season both were @ 175 (since I’ve had the boat.
    I found this video, at 0.40 he mentions that his bypass hole is blocked off on the block (same as mine).
    https://youtu.be/hAAFalFpV-Y?si=BvgZdCJCEQFv9f-b
    Here he is explaining the bypass hole in depth.
    https://youtu.be/miRWgArxH7c?si=QOZJRLpgwr1JqyUx
    So, all engines with Vortech heads do not utilize the bypass hole!
    I kinda wish I started this topic in its own thread. Luckily I’m anal and knew things weren’t adding up. I don’t think they even make the pumps without the bypass hole anymore. All of our engines (most) have an inactive bypass hole. I’ve searched everywhere and there’s extremely limited stock on pumps without the bypass hole anymore. I’m curious how many of you guys have the bypass pump?
    Start a new thread and ask @raybo3 to move the posts!
