I had my canvas guy run stitching along all of the seams on my bimini top. I noticed some areas where the pieces were “welded” together starting to disbond. I also waterproofed it when I got it back.
Changed out the coolant in both mains. As always, big motors are thirsty. It's 30 gallons at $40/gallon. This is why I'm still working half-time at my day job.
You guys are really ahead of us here in Canada, with a long winter and more Snow this Sunday. Looking like May by the time we can be in the water. But working on another big block fibre glass project
2008 Rinker 400 EC (sold Aug 2025) 2015 Scarab 165G Laser Sailboat 2002 Seadoo Explorer 2023 Seadoo Spark Trixx x 2
Wow that is some expensive antifreeze. What makes it so special?
I think it's a diluted form of Liquid Schwartz. I looked for aftermarket coolant that meets the Volvo spec, but couldn't find anything in the US market that I felt comfortable with.
@SimcoeRinker400@aero3113 I got jealous of your four wheeled toys so I joined the club. I had a E46 M3 coupe in my youth and it was time to get another one. FB Marketplace is a dangerous place.
Starboard water pump had a very small seep at one of the edges. I replaced the impellers and didn’t use any sealant on the gaskets over the winter, I was tired of scraping and cleaning the sealant and wanted to see if the sealant was needed. It probably would’ve sealed itself but took it back out. Port side was fine. Pulled off the starboard pump and sealed her up, no more leak. I also found the pulley was rubbing on a clamp tail. I heard a strange faint sound when I started her but I thought it was the alternator. Readjusted the clamp , also painted the wear mark!
Did valve adjustments on both engines. First time for them (and for me). Now they are back to purring like happy little kittens. Also replaced the valve cover gaskets, which should clean up a couple minor oil leaks.
I looked at another FJ40 today that I came across on Marketplace yesterday. As I pulled up to it, it looked promising, the body looked solid. I took one look under the hood and told the owner I wasn’t interested. Had a lot of rust in areas that would make it too big of a project! Would’ve been cool to have two 40’s and I just ordered the Land Cruiser 250 last month. I should have it in a week or two.
After years on the waiting list we finally got the call & have a slip set up for this year. Yesterday was the first time seeing it in person. Can't wait for the weather to get nice
2015 Scarab 165G
Laser Sailboat
The valve cover is HUGE !!
I had a quote for $2k for valve adjustments by a pro. After a lot of research and tool-buying, it's not that hard. Diane helped!
