1…136137139141142…146
  • aero3113aero3113 Member Posts: 10,021 ✭✭✭✭✭
    I forgot to take a pic of her in the water but she’s in!⚓️
    I got to use my magnet today, dropped my pliers 😂⚓️
  • FormulabenFormulaben Confirm Email, Member Posts: 232 ✭✭✭
    I had seen a boat last year with a foot shower at the area where one would board and I knew I had to have it, especially given its simplicity. I always dock starboard side, so putting it there at the swim platform was a no-brainer.
    This mod is particularly easy and inexpensive since you can simply tap into the fresh water system. I took a SharkBite T adapter and tapped into the cold water PEX line at the area where it goes forward at the front-starboard bilge area (getting my body back there was not fun.) Then I added a much-needed accumulator (again, with SharkBite connectors), a SharkBite shutoff valve, an open/close solenoid with SharkBite connectors, and then the faucet, via...wait for it...a SharkBite adapter. All in, I'm at <$300 for parts, including the added accumulator. Of all the parts I was really surprised at how inexpensive the water valve solenoid was and how spendy and numerous the SharkBite connectors were.
    PARTS:
    Nozzle $120  (alternative nozzle $61)
    Solenoid $22
    Switch  $9
    Ball Valve $21
    Accumulator $43
    Sharkbite Adaptors & PEX hose (Home Depot, $74)
    The only part that was a touch scary was where I drilled the hole for the power button, but once I knew that I wouldn't need to add the nut to the back of it and simply secure it with silicone it was far less worrisome.  I drilled a smaller size then Dremeled out to a custom tight fit, securing with silicone. The only electrical here was power going to the solenoid via the momentary push switch, and negative on the solenoid to ground...simple.
    I was able to test it but forgot to take pictures, but will add one later. I tried to find the same nozzle that was on the Eliminator boat, but was unable (they were sold out of that nozzle at the time.) The only low-profile faucet nozzles I could find were the "non-ligature" type and were quite expensive since usually sold to hospitals or prisons. I like that it is stainless steel and has a wider spray pattern with more volume than the one on the Eliminator boats. I placed the nozzle to spray where you would be as you board, with your hand conveniently resting on the gunnel where the switch is. Putting it there keeps it somewhat hidden and not prone to accidental use.
    My old hose nozzle must’ve had some water in it and froze/cracked over the winter. Bought this one from Home Depot and really like it. Small, compact and don’t have to worry about dropping it and damaging anything since it has rubber on it. Does stream and spray with the pull of the trigger. I guess it can be used with hot water.
  • grouch0jrgrouch0jr Member Posts: 260 ✭✭✭
    Whoa that's awesome. Are you happy with it?
    Brought mine out of shed since tilt hydraulics and cylinder replaced and all good. Power washed, buffed below rub rail and cleaned drives ready to paint. Launched the inflatable and on its dock.
    I only got to test it so far...unfortunately due to being behind on the misting system and work I'm not able to splash her until Thursday, just in time for Memorial weekend. I'll update with an actual picture at the dock but just the test made me happy. Not sure how much it will get used but it was more of a "I have to have that!" type of mod.  The misting system will be insane, presuming it works...
    Very cool @Formulaben
    Been hot here so buffing has been tough. Finally got both sides done, only the stern and I can do that in the water sitting on the swim platform. Go in in a day or 2 - finally.
  • Rich_Rich_ Member Posts: 366 ✭✭✭
    Two more ready to go. Second whaler on the rack for paint, second waverunner getting battery charged.
    And here is the first test of the high pressure misting system. Yes, that bimini is last year's project that I promised I would post but will have to wait for another day, but it's basically an aluminum frame with two 560watt bi-facial solar panels feeding a 3000 watt solar charger/controller/inverter. This allows to power the pellet grill, lounge fridge/freezer, battery charger, etc.
    Rain stopped for the final day of the long weekend.
    I bought a new drive reservoir assembly for my starboard side. The old bottle has a slow drip at where the wires come out on the bottom. $51.99 on Amazon.
  • YYZRCYYZRC Member Posts: 5,536 ✭✭✭✭✭
    I think that's cheaper than IAC filters are now.
    Crazy right @YYZRC . I looked on eBay also and everyone was selling over priced new aftermarket or used OEM. I thought it was pretty cheap considering it’s OEM.
    Talking about overpriced parts….
    This is a Radio Altimeter I had to have replaced for our G650ER yesterday.
  • captkevincaptkevin Member Posts: 603 ✭✭✭
    Ouch
  • rasburyrasbury Member Posts: 9,005 ✭✭✭✭✭
    Wa wa what? 86 grand?
    LoL!
    I paid $73k a few weeks ago for a new oven for the G650. Actually, it was a repaired unit. And $34k for a repaired microwave for the G500. These ar cheap compared to some of the other Avionics and engine parts.
    LoL!
    And my wife thinks boats are expensive...at least your jet makes money I assume...
    Yeah, I think knowing where the ground is is pretty important.  :D
    @rasbury
    Privately owned, not for charter.
    We removed the stripe on the side of the boat. I have new letters to replace the bayliner lettering on the side as well. We have someone coming to give the boat a complete polish top to bottom so I wanted this down before they started.
    I also installed two victron DC to DC chargers, Victron inverter, and two 12v Epoch 334ah lithium batteries. I have the cerbo gx and touchscreen monitor on order to arrive tomorrow as well.
    The stereo is finished so now I have 4 new fusion speakers outside with remotes in the cockpit and fly bridge to control each of those zones.
    We have been very busy taking care of all sorts of small and big projects.
    It actually looks pretty nice without the stripe or lettering on it.  Gives it a nice clean look.
    Looks way better without the stripe. What did you use to take it off?
    Removing the stripes really gives it a different look. I removed mine on the 330 and feel it updated it.
    I have the wheel.to remove it and that's what I started with but even at slow speed I didn't like how hot it got the gel coat even at low speed.
    We ended up just using a heat gun yes that was less hot than the wheel. Razor blades and carefully peeled it off.
    Both boats look better without the stripes. We have been working on removing graphics a little at a time. Used several wheels & wasn't real impressed. Will have to try heat gun.
    We also used the spray bottle off goo gone not good off. That help get bits of stuff off and lubricate the surface for scraping.
