Boat šank
GMSLITHOGMSLITHO Member Posts: 1,625 ✭✭✭✭
So my boat šank at the Marina Belostenčev was leaking and rippedc what Are my chances with insurane
  • GMSLITHOGMSLITHO Member Posts: 1,625 ✭✭✭✭
    The got the boat out of the water so minimul oil and gas spilled
    Ana suggestions
  • PickleRickPickleRick Member Posts: 4,400 ✭✭✭✭✭
    If it sank because of a faulty bellow, you're likely out of of luck.
    But when i was out last week i think i hit something but docked and didn’t think of IT
    That improves your chances if you can see damage from a strike
    Insurance wats the motor pickled my Marina mecanic is out so i was going to do it tomorrow
    rick whats better to fill  it  back up with oil or diesel im going to pull the starter and alternator also
    edited August 20
    Id pickle it with diesel as its about the cheapest.
    If you are in fresh water and clean it out quickly you should be ok.  Even with fresh water, it doesn't take long for things to start rusting.
    Trude today but its raining heavy ill ask the Marina to bring it inside
  • rasburyrasbury Member Posts: 9,000 ✭✭✭✭✭
    So have you been able to see it out of the water? Is the bellows damaged? I'd thing it would have to be about gone or your pumps would have kept up with it? Any work done on the motor recently? I thought I was sinking but was  my fault. I pulled my motor to re seal the transom and when I put the motor back in i did not have a hose tight- could not see the leak. Scared the crap out of me.
    The shift cable boot ripped
    Pulled the spark plugs cauberator and altenator evacuated ALL the water filled with oil and diesel and cranked IT over a few times i think IT can be saved
    Everything covered with oil
    Depending on what coverage you have, that should be covered.    Hopefully it won't take much to pit her back on the water
  • raybo3raybo3 Administrator Posts: 5,620 admin
    Oh man that $ucks good luck getting her fixed up and back in the water.
  • FormulabenFormulaben Confirm Email, Member Posts: 230 ✭✭✭
    edited August 22
    Oh man, this is sad. :(
    Insurance adjuster will be inthere Tuesday
  • captkevincaptkevin Member Posts: 602 ✭✭✭
    Good luck
    Insurance covered everything
    Looking for a new boat
    I was actually thinking about buying it from the salvage company but when I took another look I just couldn’t do it
    Probably a smart move. Good luck in the boat hunt!!
    They totaled the boat? Wow. They did not hot you for maintenance on tge shift boot/bellows? From what you posted so far, sounds like you are a lucky guy!
    Very lucky guy, share your insurance brokers information lol.
    And a perfect time for end of season sales on privately sold boats.   Get them before winter storage begins
    Progressive I had a receipt from the marina for all that stuff replaced 3 years ago I’m going to look at the exact same boat tomorrow
    If it was replaced 3 years ago, why did it fail? A shift boot would be really hard to hit.
  • aero3113aero3113 Member Posts: 10,012 ✭✭✭✭✭
    Great news @GMSLITHO !!
    Hey boss, where did this extra hose clamp go?
    I think they manufacture them overseas somewhere
    I think a muskrat got to it
  • SpyderwebSpyderweb Member Posts: 960 ✭✭✭
    I had a 2 year old Bayliner 285 sink at the dock due waiting to be pulled end of season.  Muskrat chewed several boots including shift cable boot.
