Boat šank
2»
  • rasburyrasbury Member Posts: 9,001 ✭✭✭✭✭
    What in the world are they after? I've seen squirrels get at coolant bottles in autos after the coolant but..
  • SpyderwebSpyderweb Member Posts: 960 ✭✭✭
    I’ve heard there’s something in the rubber they like.  I’ve also been told to always leave the boat with outdrives straight.  Boots are protected better that way.
    That makes sense  @Spyderweb. I've said before, after chasing various leaks, the express cruiser and up have a lot of holes in the hull for something.  Any I/O I guess...after putting my motor back in i had a heck of a time with the shift boot staying on my bravo III...
  • PickleRickPickleRick Member Posts: 4,400 ✭✭✭✭✭
    Im about to tackle the shift boot on my bravo 2.  The lake is down nearly 9 ft and i was rounding a point that should still be 10 ft deep according to the chart and it was maybe 4 ft. I trimmed up and slowed way down.  Got to the docks where the admiral could take some trash to a dumpster and noticed i no longer had forward.   I had netural and reverse.   I could disconnect the shifter from the engine and push it into forward.   We walked it onto the trailer by hand and towed home.  Removed the drive to find the cable had separated from the crimped on threaded fitting end.
    Theres hardly any room to access the shift boot.  Im due for a new gimball and bellow come spring so i figured id do it all at the same time, bellows are easy to work with when its 97 degrees outside anyway.   I hope with the u joint bellow removed i have plenty of room to work with the cable and shift boot.  Removing the helmet isnt something i want to get into.
    Going to check to verify the lube oil hose is still nice and flexible while I'm in there, its also about 5 years old
  • aero3113aero3113 Member Posts: 10,017 ✭✭✭✭✭
    Congrats @GMSLITHO ! 🍾⚓️
    Spyderweb said:
    I had a 2 year old Bayliner 285 sink at the dock due waiting to be pulled end of season.  Muskrat chewed several boots including shift cable boot.
    That is crazy!
  • toolmaker312toolmaker312 Member Posts: 130 ✭✭
    Glad to hear about the insurance.I am selling my 2003 312. It is on face book in Downers Grove Il. It is pretty clean with recent Gimbal bearings on both sides.Always fresh water. The are redoing our slips and I am now paying for a 40 slip. Good reason to get bigger .
  • captkevincaptkevin Member Posts: 603 ✭✭✭
    Our slip is 34' so we have plenty of room for upgrade as well.
