new genny problem, water impeller does not turn and pump...
rasbury
Member Posts: 8,799 ✭✭✭✭✭
Well, my 270 has the 5 something Koler genny which I have only run a couple of times since purchased 5 months ago or so...changed the water impeller, plugs oil and filter and tested it but never used it. Planning on using this weekend and tested in my yard yesterday or about 2 hours and ran fine, shut it down. Just for giggles today, I fired it up which it did but no cooling-checked my hose as I thought I had a little kink in it and started it up and still no water. Checked the inlet filter and it was clean and full of water so it was at least getting this far. Pulled the inspection cover off and pulled the anode- no water in the tank at all came out. Pulled the water pump cover off thinking a impeller problem and it looks fine. I turned the engine over and it does not spin it nor the shaft it mounts on....what the heck happened? I'm going to look at the parts manual so I can see how that goes together but this does not sound good,....
Post edited by Dream_Inn on
http://www.partsfortechs.com/asapcart/359448-sleeve-rubber-kohler-p-978.html
Me thinks I know the 5e a bit too well. arrrgg
Oh, and that is one used looking impeller!
Here's the pics to add clarity for the next guy. My 5E is an '04 ver and the access was super easy. 15min job with simple access to all bolts/parts. Mike
