Toilet
Britinusa
Member Posts: 306 ✭✭
Anybody know what kind of toilet was in the Fiesta Vee 250? I have one with a camper toilet and there are 2 pipes in the bathroom,
one looks like a drain hose, where does it go? its open right now.
the other is a water supply hose im guessing that comes from the water tank.
Will i have water leaking into the bathroom from either of these hoses?
What type of toilet did it have? can i buy one?
Thank you here is my plumbing, so im clear the one on the right draws water in from the lake, and the left dumps into the black tank, and i hook up a suction systen the the valve outside that says "waste"?
Directly outside the bathroom is the waste connector, could it be that the toilet had a holding tank built in?
On my picture above, the waste pipe goes in a downward angle, so it looks like it goes towards the sink area, ill try to get a camera behind there tonight.
Next job will be figuring out how the sinks work, there is a water pump on the system but no switch anywhere on the dash?
Any suggestions on putting in a proper toilet? i have seen the ones with the holding tank built in but that will be too high because the toilet sits up on a raised ledge.
How hard would it be for me to do some plumbing and add a holding tank somewhere on the boat, either in the engine bay, or i saw a sailboat that had one under the seat in the main cabin, just not keen on the idea of the waste tank where we eat and sleep, but that would be easiest as its right next to the head.
I was just looking at the Jabsco lite flush electric toilet seems to be the right dimensions for me.
So the waste tank i know needs a pump out line, im guessing that come out the bottom of the tank? whats the difference between the vent line and vacuum relief?
a tank vacuum relief valve is when you do a pump out it prevent the tank from imploding.
If you do a bit or research on this site you should find infos on both subject.
Good luck.
The only question i still have is the existing waste out port is 8 ft away from where the tank will be, is that too far? if so ill just cut a new hole above the new holding tank.
I also just had the boat wrapped so i'm not doing much now, apart from refinishing the table, getting rid of the white melamine top and replacing it with cherry and a compass rose inlay
So now i have a new problem, How will i get water to a toilet? can i run a line from a fresh water tank, not my potable water tank directly into the intake pump for an electric toilet?
I was looking at the Sealand toilets and it says they hook up to my pressurized fresh water system, easier then cutting new holes below the waterline for a river water feed i think.
Paul
