Gas during winter season
hanzelvh
Member Posts: 36 ✭✭
I was used to fill off my dieseltank 100% before putting in winter storage, but now I changed to gas.
I heard that gas is loosing power after few months of storage.
To have 500+ liters of gas with less power is not attractive.
What is your experience?
previous 280EC with VP D4-260, now Bavaria 33HT with twin VP 4,3
http://www.boatus.com/seaworthy/ethanolwinter.asp
http://www.boatus.com/pressroom/release.asp?id=842#.VFffPvnF9V0
One article says to definitely fill the tanks. The other says that empty is good, and full is good, but you should pick one or the other rather than leaving it half-full.
How's that for a non-answer?
First, I start with solid research and good intentions. Then, I continue using the boat until the weather is ridiculously cold and all nearby fuel docks are closed for the season. Then I winterize the boat with whatever fuel happens to be in the tank. If my mechanic has a couple bottles of fuel stabilizer, he dumps it into the tanks. Four months later, I de-winterize the boat and everything is fine.
hanzelvh -- the method Michael T described is probably better.
STORING YOUR BOAT ON AN EMPTY TANK
First off, let me refer you to a website which has the MAX water content of air at various temperatures:
http://www.engineeringtoolbox.com/maximum-moisture-content-air-d_1403.html
So you will see at 86F, the max moisture content (100% humidity) is 30.4 g/m3.
You will also see at 14F, the max moisture content is 2.31 g/m3.
I would call this a worst case scenario - somehow 100% humid 86F air completely filled your gas tank and all the air in that tank was cooled to 14F.
This means that a maximum of 28.1g of water could condense out per cubic meter of tank volume. My tank is 285L, or 0.285 cubic meters. So at most 8 g of water could condense if I had EVERYTHING working against me. That is 1.5 teaspoons of water.
STORING YOUR BOAT ON A FULL TANK
Now for the other alternative - you have to look at two scenarios (1) storing ethanol containing fuel, and (2) storing "ethanol-free" fuel (in brackets because "ethanol-free" doesn't necessarily mean it is free of ethanol, but meets a minimum standard.
I am going to refer to this paper, for details - it's a good read if you have time:
epa.gov/oms/regs/fuels/rfg/waterphs.pdf
1) Ethanol containing fuel. This is about the worst scenario possible. See this website:
http://ttypes.org/ttt2/ethanol-blended-fuels
The problem is phase separation. If there's enough water (at 14F it needs to be higher than 0.35% water by volume), then every 5 gallons of fuel turns into 1/2 gallon of alcohol/water mixture, of which 1/4 is water and 3/4 is alcohol. That's 2.5% of the gas turning into water! In my tank, if it was full (285L), I would need around 1L of water in the fuel before phase separation would occur at 14F, then it would make over 7L of water!! Boom!
However, note that we calculated above that an empty tank can only produce about 8 mL of water, so that's not enough to cause phase separation for a full tank (and you wouldn't get that much condensation to begin with anyhow with a full tank). Not on it's own anyhow. I would say it's only a problem if the gas has been in the tank for a long time and has already absorbed lots of water from ambient, and it only needs that last 8mL to push it over the edge.
Verdict - I wouldn't keep the tank completely empty, as doing so (a) increases the amount of condensation, and (b) with less gas in the tank, it takes less condensation for phase separation to occur. On the other hand, if you have a full tank and can't consume it quick enough, you actually increase the chances of phase separation, as water will absorb over time (over many months). Don't take my word for it, but I would probably leave 1/2 tank of gas, unless I knew I would consume more in the first month after coming out of storage. Note, some sites do talk about concern of gas tank corrosion if phase separation does occur - so really you want to avoid this. The most important thing is to stabilize that gas, and use it as quickly as possible to avoid phase separation. I personally would be more worried about not using that gas for a long time, as that is the biggest risk of phase separation.
2) "Ethanol-free" fuel
Pure gas does not have the ability to absorb water (well not that much). In essence, when it reaches it's water saturation point, then any extra water just won't absorb and it settles out. It doesn't phase separate (at least that's what the sites I have read have said).
So essentially the water you will get in the gas is the water it can't absorb. If the gas was saturated with water, and the tank was essentially empty, then that means about 8mL of water in 285L can be water. I'd imagine if you fill the tank with fresh gas in the spring, some of the water would re-adsorb into the fuel, and the turbulence would disperse it fairly quickly.
I can tell you first hand that last winter I stored with a full tank of ethanol-free fuel, added sta bil as well, and I basically didn't have to fill my tank all that much this summer (didn't do enough boating). I did notice more black fumes from the exhaust, especially on starting the engine. There was also some minor carbon deposits on the water surface (not a lot, but it was different to last year, when I had fresh gas).
Verdict - chances of a water problem are a lot less with ethanol-free fuel. This small amount of water (8 mL at most) the fuel/water separator will easily handle that, especially because it won't come in as a slug (not that little in so much fuel). Still stabilize the gas, as "ethanol-free" fuel may not be totally free of ethanol. In my opinion, I don't see a big issue having the tank 1/4 to 1/2 empty. If you plan on consuming a full tank in the first month after it comes out of storage, then sure, I would go ahead and fill the tank.
It separates when enough water has been added. The water is absorbed by the fuel from the environment. If some rain gets in (open fuel cap), then it can happen in minutes to hours.
I'm guessing the tank "breathes" over time. Moist air comes in, gets cooled, sheds water into the fuel, and then more moist air comes in a few days or weeks later. But the real key is -- to keep your boat healthy, use it often!
(1) to show me in my insurance policy where that particular exclusion is written up, and
(2) to prove to me that an empty tank is materially more dangerous than a 1/3rd a full tank (which is the general guideline adopted by mariners globally for a safe minimum level).
There's no way they could prove this, because it isn't true, in my opinion.
Perhaps we should all be asking our insurance companies the same questions.
Tony
Salt Shaker 342
Tony, I am pretty sure a spark above a half full tank would still cause an explosion. I would assume there's enough air in there to ignite. After the explosion though, as you point out, you still have all of that liquid fuel, which would have dispersed everywhere around the boat from the explosion, and now be burning things down rather quickly (or at least what is left of the boat).
Anyhow, this may have to remain theory, as this is one test I'm not prepared to do.
A $3M umbrella policy costs about $150 a year.
