Attaching a Magma pedestal on the swim platform
Stodge
Member Posts: 2,738 ✭✭✭✭
Has anyone attached a Magma grill pedestal to their swim platform? The base has holes for 6 screws. I was thinking I could just do pilot holes, get some #10 or #12 3/4 inch stainless self tap tapered head screws, and put a squirt of silicone in the holes before the screws. Have other folks used the same method?
I'd maybe mine under the ladder hatch, so its out of sight when not in use.
4200 sealant .
There are many reasons to just do it right. A through boat with a backing plate is the way to go.
Joe why can't you put a backing plate in?? You just apply a thick coat of epoxy between the deck and backing plate. This will make sure the plate sits flush and stress is distributed.
Gary, the water looks pretty clear there. Is that the bottom we can see in the picture?
The votes for through bolt have spoken.
DI the platform has stringers but there is plenty of space where I plan to put the base.
I dont think theres any way to get a backing plate or thru-bolts with a molded in platform though.
Stodge, one thing I was always concerned about (& why I never put a pedestal mount on my prior boat - 310) is stubbing your toes, especially my kids. But the newer mounts have a lower profile that so far has been good. One 342 that I raft with has two mounts, one in the aft middle of the platform, the other in the aft corner. Depending on where he sits, he'll put a table on one, and the grill on the other. Pretty decent setup. Another secret use for that pedestal mount, but a nice beach/table umbrella. Put the pedestal pole up, put the umbrella in & you have instant shade! Since mine is in the corner next to a cleat, I have a beach umbrella, with a small rod that goes to help twist the base into the sand, that I use to tie to the cleat. Just a thought!
What is under that lid opposite of the swim ladder lid? I don't know how deep the pedestool acceptor is, but can you put it through that lid. I would then have a latch to make sure the lid stays closed (so it doesn't flip open with the grill on).
Last idea is to put in right on the walk through inbetween those stern seats. If you need to get access to the swim platform it looks like the seats are low enough to just step over. OR!!!! What about under one of those back seat cushions?? Just take the cushion off when you want to grill. That will give you a whole side of the boat to grill on. And you won't need to worry about grease getting on the cushion.
And I dont know why, but mine doesnt have the starboard lid, although you can see the smooth mold marks where it should be. I wish I did have it, since I could use it for the dog's swim ladder and leave the other one for people.
I did kinda like Handy said, but I used a standard tabletop grill and put it on the counter in the cockpit (with a thick towel underneath to protect the Corian), and it actually worked well, but I would definitely not do anything greasy, since it would easily splatter onto the seats and carpet....
06 Rinker 270
We used to spend the night on our 280 without a genny. Had a propane grill and would cook on that. It's not hard to "camp out" without a genny.
We have a 12v box fan that works well.
