What size/type dinghy for my FV270?
I am in the market for my first dinghy for my (new to me) FV270 and I'm not sure which type to get. I'm thinking that I should keep it around 9' long due to the boats 9'1" beam. I'm looking on Defender.com at the different types(solid panel floor, slat floor or air floor) and wondering which would be best for me. I will most likely inflate/deflate as needed or just tie onto the swim platform between destinations... Where does everyone store their dinghy, outboard and fuel tanks on their FV270's? Was thinking about getting a 6hp Tohatsu, just trying to decide on fuel tanks(built-in or seperate).... There's just too many options!!!
I enjoy my dinghy almost as much as my Rinker, and the dollars involved are reasonable for what you get, considering a good SUP board runs a grand too.
I'm thinking I'll strap it to the swim platform, but have it forward-facing with the stern of the dinghy dragging on the surface of the water. That way a portion of the platform is still usable for walking.
I just moved up from an airdeck to a RIB. Best move I made.
As far as keel, mine has a air keel that really helps it get more on top of the water (it will actually plane with just me and the 3.3hp!)
A dinghy really makes anchoring out more enjoyable! it allows you to explore areas and get to land when needed. Also allows you to anchor outside of towns without paying the marina fees.
Based on my experience, seam leaks are a death sentence for an inflatable. The boat may be useable, but there will be at least a small air leak that will require frequent re-inflation hassles.
RIBS are the ultimate, but having a smaller Rinker, weight and size are critical factors. The dinghy I'm ordering only weighs 53lbs thanks to its short length and high pressure floor. The limited payload is fine for what I use it for, tendering and zipping around the harbor, plus snorkeling at Catalina Island.
Andy
With two lines from over the dingy tubes to the canopy frame and two 6'x6' tarps the swimstep shower can be made semi private. Also I made a BBQ table/dingy engine mount that swings up and down and bolts on to the factory grab handle bar on the transom just above the swimstep pull out shower hose.
LJ
http://www.westmarine.com/buy/west-marine--pru-3-performance-roll-up-inflatable--14272488?cm_mmc=EM-_-Promo-_-141205-_-N/A
Catch us on Kelley's Island at the Seaway or Portside Marina or Middle Bass at the State Park Marina MOST SUNDAYS and weekends in July! Call My Dinghy on Channel 16.
06 Rinker 270
I had to replace a broken bolt that took some elbow grease, but definitely worth the $$ saved. These go for $400+ easily in good running condition.
Now this is what you should have got!
06 Rinker 270
