outdrive slipping??
New to boating. I have a 2002 captiva 232 cuddy with a 350 mag and bravo 3 outdrive. I was taking off earlier today and the rpms went higher than usual for the amount of throttle I gave it, then about 15 seconds later the rpms dropped to normal and the boat took off like I hit another gear. I would compare it to a clutch slipping in a vehicle. Any ideas on what it could be? Thanks in advance
And since its all comin out, yeah, bellow up.
Make sure that engine is aligned... For the life of me, I can't see how a gimble that's properly maintained and a coupler that's less than ten years/2k hours old can fail unless it's a defect in the manufacturing, unless the drive and engine aren't aligned.
Maybe the engine wiggles a bit over the hours, or something like that.. The coupler can absorb some of that, I'm guessing, but it wears on it I'm certain. Hence.. It gives.
BD: I did mine last summer, too. It wasn't the coupler as much as it was the tunnel, though the coupler wasn't in the best of shape.
Oh boy, can't resist...& that speed is...."slow".
Raybo, you definitely lucked out.
I have a buddy that caught a chain (that somebody must've left cause they couldn't get their anchor out) around their bravo 3 unit. Not sure of all the damage yet, but definitely some teeth missing from gears is known.
