Time to plane
NRath
Member Posts: 135 ✭✭
Captain newbie here... I've taken one trip, the sea trial, in my Captiva 192 4.3GXi, stock prop (14.5 x 19º, I think). I had read a review about it and it said time to plane was like 3.8 seconds. Having been boating a fair amount (with other people), I knew that was pretty quick. However, my girl is timed at more like 8-9 seconds. With a couple people in back- wouldn't do it. Move some weight up front and it'll plane. 3 people on board- speedo hits 49 mph. Compression checked out good on all cylinders and it seems to run like a top so far. What gives?
Also, the reviewed boat was a Merc 4.3 non-fi, so it should have only been 190 hp, vs my 225...
Should I try again with no other passengers? Of course, a prop change or trim tabs would help. Just puzzled and a little concerned why the reviewed boat would be so different.
What is your wide open throttle rpm?
Mark
2019 MTX20 Extreme
Read conditions of the test, they should specify tank level, number of people on board, etc. I'd imagine at 3.8 seconds they basically had 1/4 tank of fuel and only the boat operator on board, perfect water conditions (flat water), etc.
Do you have smart tabs? That will make a big difference.
Dave
As for test conditions, I didn't see that in the article. I was def worst case w/2 passengers and a full tank of gas, though.
My boat is all stock, as I assume the one in the review was.
Good comments, keep them coming! I hope to get out tomorrow evening for an hour or so.
Interestingly and unrelated, I hit about the same top speed w/3 people and a full tank vs 2 people and an empty tank. Empty? yes, because then I ran out of gas. lol. I had 3/8 tank when a left the dock! So, my first time fueling came thanks to a friendly lake front owner. I like new friends...
Mark
2019 MTX20 Extreme
http://rinkerboats.vanillaforums.com/discussion/comment/4845#Comment_4845
Mark
2019 MTX20 Extreme
Also, the outdrive ratio is 1.79.
Pulling a tube or single skier tonight, it really seemed to struggle getting up. So much that the admiraless noticed and blessed smart tabs without me bringing it up. Had 2 in bow, pass seat, and myself- nobody in rear. And, a full tank of gas
Mark
2019 MTX20 Extreme
Many analog tachs used to be adjustable through a small port on the back of their housing using a jeweler's screw driver. It was amazing that some of them could be out of adjustment by 100-200rpm just by where the needle was in reference to the metal pin at the 0 rpm designation. Anytime a friend installed a new tach we used a reference tach to calibrate it. The only tach that I have never heard a calibration complaint with is the Gaffrig tachs. They seem to be flawless.
I spotted the cyl adjustments on the back of the old tach last night when looking for adjustment options, but didn't have time to pull out the one in the boat to check it. Spent too much of the evening having dinner on the lake
Another thing I looked at yesterday- the spray. At about 40, I saw the spray was exiting the side of the boat about 12-18" behind capt chair. Slowing down into the 20's brought it up to even with capt chair. I'm guessing that's only really relevant for discussing trim, right? Or, are there some other takeaways from the spray pattern?
Yes, NRath you are correct. The spray pattern is relevant for trim, total load and side to side load. Spray patterns from the transom or wakes can also tell a lot about the boats attitude and set-up. I remember years ago a buddies boat with an uneven wake that just looked weird. We adjusted loads etc to balance the boat but the wake still looked weird. Closer measurement showed the transom plate of the engine was not square to the hull. As someone mentioned in a post a couple of days ago wake differences (patterns) with twin engine boats can be a telltale sign of problems. You are wise to note the attitude of your boat, that way you are more likely to notice a change.
The only bummer is that both will be here about the same time and I'd really rather try one at a time to get a feel of the difference of each. Only got about a week left with the daughter before school starts, so I'll be all in as soon as i can. I can swap back to the 19x3 in the fall.
When you say smart tabs do you mean they adjust themselves (spring loaded) or helm adjustable? Any tab should make a difference but I like the captain adjustable from the helm better. It will be interesting to see what the new prop does. I had a 4.3 LX (as I said before) we used to call a 17" pitch prop on that boat a ski prop as it gave a better hole shot to pull a slalom skier out but less top end. We also had to be careful that we didn't over rev the engine as that prop would increase the rpms by 200 rpm at wot. I would think the 4 blade will drop the revs so you might not over rev but you may want to make sure that you don't lug your engine with too much prop for the engine. It takes more grunt to turn a 4 blade.
Sounds like we're on the same page prop wise. I read that going to a 4 blade, dropping 1" of pitch would be about equal to a 3 blade. I need more out of the hole to boot, so going down 2" seems like a good thing. Hopefully I'll get the good ski prop out of this. I just wish I had ordered it a week earlier!
I'm staying well clear of 4400 rpm's for now until I get a second tach to verify my Faria reading. 3400 on the Faria is about the limit at this point, which gets me to 45 mph (lake speed limit). The engine sounds fine at this, or whatever rpm it's running. I'm a lifelong gearhead, so paying attention to how it sounds and feels is second nature.
Related question- do V-P and Mercury have rev limiters on their engines?
With 2 in the bow, 3 in the cockpit, there was very little bowrise. Probably reduced by 75%- Granted the extra 200#'s in the front was part of that. In later starts, I did experience some bow rise with 2 on tube and maybe one in bow, but easily 1/2 what was typical before. The admiral was able to notice the difference and commented on how much better it was both in bow rise and ease to plane. My point there is that if a non-driver notices, it has to be pretty significant.
RPM's were obviously running higher given the pitch change. I never got it would up over about 3500.
I will get some good #'s in the near future for comparison.
Great news........but hardly a surprise! The lack of significant bow rise is very noticeable as well as the reduced time to plane and minimum planing speed. I'm amazed though that you're able to run a 17" prop without ridiculous RPM readings. I tried an 18" 4-blade cupped stainless on my previous 192 that had a 4.3L Volvo SX-M. It pulled like a tractor but the WOT was way too high. You really couldn't do much higher speed cruising. I ended up settling on a 20" 4-blade cupped stainless for all 'round performance and it has stayed that way ever since. The boat came with a 4-blade aluminum but I forget what the pitch was....maybe 19"?
Yes, weight distribution will make a huge difference as well in the 192.
Mark
2019 MTX20 Extreme
