SeaDek install
MarkB
Member Posts: 4,000 ✭✭✭✭✭
Just got this installed.
Post edited by mvn on
let us know how it wears.
Home port: Hammond Ind.
So here's my SeaDek additions this year.
Port side access step
Platform Step
Starboard side access step
Looks Fantastic! MT
Has anyone had it installed in the cabin?
Once you rip out the carpet, you will expose raw fibreglass (does not look nice). The carpet resin will need to be sanded down, and then I'd apply a gelcoat to get the base nice. SeaDek will stick to the gelcoat, as it's a smooth surface. The other issue is they can only make the sheets so long, so if you look at the pictures you will see various sheets with the gelcoat underneath exposed in between sheets. If the cabin area is too long, they may need to break it up into 2 or more sheets, and this would require a finished under-bottom so that it looks nice in between the sheets.
I know a few people have considered putting in a linoleum teak print covering. This can be cut to your size/shape and easy to install.
@MarkB
Thanks for the Pictures. Will purchase it now.
Regards
Boris
