cruiser explodes on lake george ny
After getting gas he turned on the ignition and it exploded into a ball of fire...He was thrown 30 feet into the water...The gas attendant pulled him out...He is in critical condition....They don't know if the blower was on or off during or after the fill up....I guess the question is whether the blower should be on filling up or after...If that was the problem....Your comments...
I even turn-off the electronics switch that Rinker puts on the helm to power the GPS and Radar and my ignition keys are keyed ALL the way off. NO spark potential is what you want. .....and as has been mentioned on this forum, I want to see that gas nozzle touching my metal gas filler receptacle.
Poor fueling practice is definitely part of it. If he had run the blower and then sniffed the blower exhaust before starting the engines, he could have smelled the fumes.
Fueling:
Everyone off
All electronics off, pull key from ignition
Cabin doors and windows closed
Add fuel, keep nozzle in contact with metal receptacle
Wipe up spills
Blower on 4 minutes after fueling
Smell blower exhaust
Lift hatch and inspect tanks/bilge
Open hatch and all windows
Start engine
06 Rinker 270
Run the blowers first. If you open the hatch and something ignites you just let the air in.
The USCG has published many articles on fuel safety. I've never seen one that recommends any of the following: opening the engine hatch, disconnecting batteries, or running the blower while fueling.
But there's universal agreement that components in the engine room, including fuel lines, blowers, hatch actuators, alternators and starter motors, MUST be marine-grade, ignition-protected items -- never automotive or household items.
That said, the human element is probably the most critical thing. Learn safe fueling procedures, and always follow them. Most importantly, sniff the blower exhaust before starting the engines. That's your last line of defense, and it takes literally ten seconds.
But....why is it unsafe to have the blower running while fueling but safe to turn it on after fueling? I mean, seems to me that it is just as safe, if not safer, to ventilate the bilge before the vapors collect than after.
I would think there is a greater chance of a spark when the blower is started than when it is already running.
And if the blower is non sparking then the fumes should not be a concern, right?
If the blower pulls them in ...shouldn't it blow them out? What really is the difference between running your blower to prevent fume accumulation than running it after to remove them?
I am a SCP and have the privilege of updating Marine Chemist certs to ensure a given space is Safe for Hot Work.
I only mention that to offer that I now have a genuine curiosity because parts of this are contrary to my training. I will definitely address this with a Chemist to get his input.
As far as vapors created during the transfer; all pumps in my area have vapor recovery nozzles. Though not 100%, when used properly they are quite effective.
Yet still, regardless of how the vapors arrive they still need to be evacuat ed.
I look at 2 scenarios:
1. When we first want to start our boats we turn on the blower for at least least 4 minutes. Why? Because we ASSUME that there are fumes in the bilge already, right? If having a blower on with fumes in the bilge is the right thing to do, then why is it unsafe to operate a blower BEFORE there are gas vapors in the engine compartment?
2. I go to the fuel dock, engine running and blower on because I am going so slow. I arrive at the dock and the attendent hands me the nozzle. Do I turn off the blower? Why? If I turn it off then, why do I turn it on after I fuel?
I'm not trying to be difficult.
Hey Dan, first I am surprised that your attendant hands you a nozzle. Where I boat gas/diesel can only be dispensed by marina personnel. One reason, how many people know to ground the nozzle? How many people know how to fill without spilling gas/diesel into the water? How many people have a clue what to do if fuel is spilled? How many marinas could get10 cents worth of liability insurance if they let boaters operate fuelling equipment.
When I run my blower for four plus minutes before I start my engine I do NOT expect there to be fumes in my bilge, as I routinely check my fuel system and hoses for integrity BUT fumes can develop despite a Captain's best assessment. One certain way is when boaters fill-up their boat tanks "to the brim" the cold gas expands and runs out the vents and off-gasses enough vapors to fill a garage (boats on a trailer) this also happens with boats in slips.
We run the blowers to draw fumes out of our engine bays via the hoses in the bay. This draws fresh air into the engine compartment via the side air ducts due to the low pressure created in the engine bay by the air being withdrawn via the blowers.
I turn my blowers off as I approach the fuel dock. Because fueling vapors are created and many escape regardless of any nozzle system that might be in place and few effective ones are (imo) in reality.
Gasoline fumes are created by the process of pumping the fuel out of the storage tank and from the natural off-gassing of the liquid. To make matters worse many storage tanks are below ground thus keeping the gas cooler. As the gas is pumped to the surface it expands further off-gassing.
Regardless of any sort of vapor recovery system, the rubber rings that some nozzles have and the possibility that the marina employee knows how to properly ground the fuel nozzle - vapors do occur. If the nozzle is grounded that helps.
All of this notwithstanding, gas vapors can develop in an engine compartment. If they do the fire suppression system is your best friend as it should buy you time to flee and trained marina staff to deal with your boat. That is if your hatch is closed.
Running your blowers during fueling is probably the best way to introduce fuel vapors into your engine bay other than pouring a pail of gas right into it.
If the proper blowers have been installed (not always the case) they are USCG/CCG ignition spark protected. You start them up to remove any possible fuel vapors in your engine bay.
Once in a while you get a really good fuel dock attendant. Earlier this summer Matt the fuel dock attendant at a nearby marina had just put about 200 gallons of 91 into our boat. I had been running the blowers for about 2 minutes. A guy waiting for gas said to Matt that guy (meaning me) can start his engines now so I can pump some gas and get going.
Matt said: first, please turn off your blowers right now, second Mr. T has three more minutes of run time on his blowers and he'll decide when to start his engines and third you, sir, are to remove all personnel from your boat, turn off all electronics and are under no circumstances to touch any of my fueling equipment - if you want to purchase gas here.
First and foremost, I thought the blowers sucked from the the bilge area and not from outside vents. Knowing this makes everything about running and not running the blower quite obvious. Thanks for clearing that up.
As far as an attendent to do the fueling, I have never had the pleasure.
