What happens when you hear...Clunk Clunk?? B.O.A.T.T
Dream_Inn
Member, Moderator Posts: 7,558 mod
Ok, I actually thought I'd get one year in with this boat and not another "T" on the ole B.O.A.T at before the last T (stands for "Ten"). I was heading out the river to go across the bay for a little lunch and just an enjoyable day. Been using the boat a ton the last 4 weeks or so and thought just a small trip and relax would be good. Not even out of the river, and something instantly didn't sound right on plane. I pulled her back, shut the stbd engine off first and the noise went away. I knew it wasn't good, so I didn't dare restart. Limped on one engine over to my favorite mechanic. He was ready with the sling when I got there (gotta love that customer service!!). Took a look and well, I'll be replacing the engine!! Sounds like a rod was thrown.
Well, sometimes you get lucky for a while. My first boat was a 240 and in 6+ seasons I went thru 2 engines. Most of it was my fault. Second boat was a 310 and we had 7 summers with the boat never being on land (kept on a lift). All was good.
This is our 4th summer with this boat, and yes the boat is great. But 3 of the 4 summers we had to B.O.A.T.T. (one case the first T was a Twenty, not a Ten - Oh!)
So yes, boating is not cheap, and no, we are not made of money. We use coupons and save as much as possible! We just enjoy our boating addiction! This one just really hurts right now! So bad that I've been home on this Saturday night (been over 5 months since I've been home on a Sat night) and it took me over 4 hours before I finally had a drink! SUCKS!
But I am very fortunate I have a great mechanic that will work his hardest to get our family back on the water and try to make it a good price and even more importantly do it right! I'll know more on Monday for sure.
@DI, fingers crossed. Have not heard of a marinized 496 throwing a rod. Hope its something else!
The first thing they had planned today was to pull the outdrive and run it to make sure. I'll say, with engine hatch up, it sure sounded like the engine. The outdrive actually engaged, fwd and rev. The noise was absolutely horrific! it is more than a knocking sound. Sounds like something gave way. I do hear you on swapping crank and rod though, I'll have to see what they say. I can honestly say they will give me a fair judgment that I can trust. I would think I'd be chancing it by rebuild and would be better off going with a new block?
Al, what if it's a rod, what's the typical reason that would happen? Too much torque on the engine? I know I'm pushing a lot of weight. Believe it or not, I try to be conscious and not overload the boat with too much weight and try to be either on plane or off plane, not sit at that tough spot between.
I'll post hopefully later today what else is found out. Crossing my fingers that maybe it's something in the upper part of drive.
Broken valve/spring
Wrist pin sliding out of the piston/rod
Broken rocker arms
bent rod(s)
Won't know until you get it apart. You can't 'over torque' the engine..it would stall.
If the block/head(s) are OK, then just a straight forward overhaul. May as well hone the bores and new rings too. As long as it is out and apart may as well redo it all.
I hope this means your season isn't over - right? Can they slap another drive on there?
SeaHare, you are correct in that I could remove and replace myself. I'd first have to find a marina that would allow me to do that in their yard. I'd also still have to pay to have the boat pulled, blocked, and then put back in the water. As far as upper unit & lower unit, I'll have to confirm, but my belief right now is both of them are hosed. So, it's a full replacement. I want to stick with OEM, so yes, I'll pay a little more, but that is the way I want to go. I'll have a 2 year warranty from Merc as well. I have a lot of weight to push, and we use the heck out of our boat, so I want it dependable. I have one of the best mechanics, period. (I think he matches up close to Al, which is saying something) Him and his entire family go out of their way to make things right! My price will be very reasonable & I have a good idea what it'll be. I do most of my maintenance, but I do draw the line with drive removal and engine removal.
Handy, good question! As others have said, put your house and all the stuff inside it on a boat, go 35 mph cruising (in your case 25mph), shake it all around, add salt/brackish/or fresh water in the mix...and well, for some reason, reliability goes out the door!
If you dont mind me asking, you said your going to eat it, why not claim it on insurance?
06 Rinker 270
As far as Handy, we couldn't have a better person to stir the pot!
