Leaking gas tank
looking for any help or info. I have a 1999 270 fiesta eve that's leaking gas. I need to know of any Long Island south shore Babylon area marina or mechanic that can replace tank. I need to know what's involved. And ball park costs.
Thanks,
Rob C.
Thanks,
Rob C.
The leaking tank has to be drained and the fuel disposed of legally. That's a few hundred bucks. Then the outdrive and engine need to be removed, not sure about the 270 but on the 250 this is a must. Another few hundred bucks.
Now the hard part. The bulkhead between the engine bay and the mid berth has to be cut away. Then the floor of the mid berth over the tank has to be removed. This is dirty labor intensive work in a confined space I would not wish on anyone.
The old tank can then be slid out. All the bulkhead and deck that has been cut away has to be replaced. Insist on making it thicker and stronger than the original. A new tank matching the dimensions of the old tank should be built by a highly competent specialized marine tank shop. Insist on using a thicker gauge aluminum sheet metal for longevity. Tank fabrication should be well under a thousand bucks.
Not sure of your local labor rates, but they are a big component of the expense. We are talking multiple thousands of bucks to get the job done. The cost will likely meet or exceed the value of the boat.
Good luck.
Andy
Andy
Andy
http://atlinc.com/marine.html
I did find a firm up in Washington State that has a product that coats the inside of leaky tanks. However they appear to be the only company doing this and there location makes it an impractical solution for any owner not located in that area.
Andy
I don't think so. Vinyl pool liners are only like 2 mm thick and there are still little 1 mm grains of rock on the bottom. Kids step on them all the time and it just moulds around them.
Andy
http://www.estainlesssteel.com/corrosion.shtml
Note that only gold, silver or palladium do not corrode spontaneously. So if you're rich, there's your answer!
Andy
Also if you use E10 gas that can eat most plastics. Not too good for metals either.
I can't imagine this adding more that a thousand bucks to the cost of the boat, not a lot on a six figure+ purchase. Of course, I'm no naval architect/boat designer/ engineer and I could be wrong.
The big headache with this job is the cutting involved and the horrible dusty mess that creates. Also, figuring out where to cut and taking a Sawzall to a boat takes some big huevos.
Andy
