VesselView instead of N2K Gateway?
diggin2day1diggin2day1 Member Posts: 1,331 ✭✭✭✭
I currently have a NEMA2000 Gateway which sends engine information(RPM, oil pressure, water temp, GPH, etc..) to my Garmin 741xs. My problem is that I am running out of "real estate" on my Chartplotter when all that info is displayed. I have a full set of analogue gauges that have been temperamental(especially the tach... Sometimes shows a 600rpm difference!). I am considering fabricating a new gauge panel and installing my Chartplotter and a VesselView 4 into it(and removing analogue gauges). If I were to do this, can I remove the Gateway from the system? Would the VesselView replace the Gateway and output the N2K data to the network? If so, I should still be able to view engine information on my Garmin 741xs right?
