Vesselview 7 on 360??
So I'm trying to figure out how to install a new Vesselview 7 on my 2005 360, but there is not much real estate. Anyone have some pictures of their installs and how they tackled the space issues? I'm thinking I may be able to squeeze it on the side of my chartplotter as I have about 11 inches on each side (see pict), and then do some creative starboard patching. Ideally I could find a new panel with no cut outs so i could make the cut outs myself and put the chartplotter and VV7 next to each other and centered on the panel. All I see on greatlakeskipper are new panels with cut outs and gauges already installed. Any ideas on where else to look?
Let me know if you all have ideas for my installation dilemma.
Also is the new Vesselview 7 and 4 compatible with smartcraft engines from 2005 (I have a 496)? All of the literature I have seen say VV7 and 4 are only compatible with Gen 1 2007 and newer engines. From my research it seems many have done this upgrade who have older model smartcraft engines. So not sure what gives.
www.tecnografic.com
I spoke to Kim at Merc today. Awesome guy and knows his stuff. He got me everything I need to go to Vesselview. I also plan to feed the fuel level into the VV so I need that additional harness. See attached for the architecture for those people considering. All you basically need is one engine data harness (blue cable), 2 JBoxes/CAN's, 1 CAN link harness, and 1 dual engine instrument harness.
For those that upgraded did you mount your jboxes somewhere up at the helm?
I was also told by Kim that my trim gauge is analogue but by locating a small "bullet plug" and simply swapping connections It would send the Trim Position into SmartCraft system as well... Digital Trim- (orange/white) bullet plug..... Analog Trim- (orange/light blue)... Unplug analog and plug in digital.... I have not physically done it yet, but I can't wait to dive in and do it... Just need a bit warmer weather!!!
I did this on my old Maxum, it was extremely easy and extremely rewarding when I was done!! I actually used an old stop sign that I had laying around in my garage. It was the same thickness aluminum as the original gauge panels. The aluminum cuts like butter with a handheld jigsaw w/fine toothed blade. I had the powdercoating shop use "Rootbeer Metallic" and it looked incredible in the sunlight. I replaced all the gauges and had the switch labels lazer etched into the panel. The cost of the powdercoating was about $100... Really came out nice, here is a few pics:
Before/After:
Final product:
Nice. Did tecnografic do yours? I just got a quote from them for $350. I have to send them my panel and it will take two weeks. I'm debating on this if I cannot figure out a different way that still looks professional.
craigswardmtb- it really wasn't too bad, very easy to work with.
here some good Infos on the NMEA system.
http://www.nmea.org/Assets/2012 ibex full nmea installation.pdf
Frencie - Thanks for the link! Would I need a Tee to install the VV?
It depends if you already have some equipement with NMEA 2000 install lf so you would need a Tee. If some of yours equipment work with NMEA 0183 protocol that would be different.
