SmartCraft 100 and 1000 Gauges
jme097
Member Posts: 1,224 ✭✭✭
OK guys, I decided to skip the VV route just because the amount of moification that is needed. I am going to the SC1000 kit (79-8M0079880) that has the tach and speedo gauges with the J box and harness and air sensor. I also wanted to add the SC100 4 in 1 gauge while I am at it to add uniformity (79-8M0052879). My question is does anyone know where tie in the 4 in 1 to receive the data? If its to the j box or where? If so, do you have a P/N? Just looking to finalize this so I can place the order. Then I am going to replace my fuel sender and the fuel sender harness that ties into the ECM harness
Any help would be appreciated!
Boat Name: Knot A Worry
JME firstly you have to decide whether you want the SC1000 tach OR speedo - you can't get both. The tach allows you to control rpm from 500 - 800 in increments of 10 rpm. I have this one, because it gives me great speed control for trolling while I fish.
The SC100 4 in 1 just plugs into the back of the SC1000. Every gauge has an input and an ouput, so you can keep daisy chaining the SC100 guages and add as many as you like. All data goes via the wires, and the gauge is designed to extra the data it needs to present what you see on the gauge. Once you get the SC1000 in the SC100 install is a breeze.
I don't have the speedo, I have the tach SC1000. So I only get a GPH reading. It's easy for me though. 30 mph / 15 gph = 2 mpg. That's what I'm aiming to hit whenever I am boating.
By the way, you'll want to make sure you get the right bezels for the SC1000 and SC100 guages. I had to order the chrome ones separately to keep with the bezels of the other instruments I left on the dash.
Looks like there are different faces.
I found this one on amazon:
http://www.amazon.co.uk/Mercury-SmartCraft-gauge-4-multifunctional/dp/B00N6DDW62
Mine is definitely a different face. There's a picture of mine below.
This is the brochure I used to order my part. See page 6.
http://mercurymarine.co.za/files/brochures/8m0063378_2012gaugectlg_lr2_0.pdf
I believe I ordered the grey-plastic model 8879946K1, assuming "grey" means the color of the face I have. Although the one on amazon also has a grey face but the text is different (mine has white text).
Did the gauges fit in the opening or did you have to get a small filler made up? I heard that the Faria gauges are slightly larger than standard gauges.
I really like that gray face to your gauges. I as going to get the white just for the normal reasons but maybe ill swap them for the grey.
Figured for almost 50% it was too good of a deal to pass up! Super pumped
Handy it's a RAM mount. It attaches to the fish finder using a plate with many holes in it so you can easily mount just about any fish finder or gps.
Yup, check out the cellphone holder to the left of my compass on the picture above. I can put on music, radar alerts, whatever on it. It's my 3rd display!
you would be lot better with NMEA 2000 than 0183 easier to install and better technology just plug in no splicing of wires.
From what I understand you would use mercruiser sc1000 it should support NMEA 2000
that was a thread on this forum in 2014 on this subject. Also NMEA 2000 is more precise and could be used with any other electronics you could add in the future
https://shar.es/14Yzw8
My next question is can I receive all my engine data from the smartcraft harness and receive my speed from N2K connection? Or do I need to install a N2K gateway from the ECM to the backbone and read everything off there?
