Anyone else find the cockpit seat too low ???
BellevilleMXZ
Member Posts: 732 ✭✭✭
I find the seat too low on my 270.....I'm always sitting on the flip up part of the seat.I'm 6ft, so not like I'm short. Did some measuring, and grabbed some 4in square alum tube, and am going to raise it. That will make it about the same height and with the seat flipped up. Anyone else find this or am I just wacked.....lol
I guess it helps to have wide beam (mine) and lots of horsepower (the boats) as both the Admiral and I can see fine at any speed. I should add that the 350/360 models have a very high helm platform which I guess makes the difference. @BMXZ, sounds like you have a great idea. Remember us when you hit the big time.....and thinking about your Rinker is always a great idea!
http://www.westmarine.com/buy/todd--cape-cod-seat-with-cushion--9413469
Andy
I don't find the bow high, I just find the seat set low. When sitting, even my knees are bent a lot.
@BMXZ I like the idea of raising the whole seat. I can think of several ways to be able to raise the entire seat at different heights: using two screw mechanisms welded to a solid plate that is screwed/bolted to the main seat frame, using two standard captains' chair adjustable rises like in sport boats that could be welded to a plate attached to the bench bottom....there has to be a lot of ways to do that cheaply that works well.
I'm going to try the 4in square aluminum tube.....its just slightly bigger than the seat frame, so good support. Seat uses 2, 3.5 in wide adjuster rails. I'll put it between the seat adjuster and boat. Polished up it should look good.
Good point on the powder coating.....
In another thread topic, lack of headroom at the helm was discussed. I have 6'7" below the canvas for standing, which I do most of the time using the curved front of the helm chair as a bolster. It is at a perfect height for that. I also replaced the standard small wheel for a 22" Destroyer model, making steering from the new higher seating position possible. This involved moving the Teleflex gearshift/throttle assembly up and to the rear a bit, but that's another story.
Andy
.....all very creative ideas but I would HAVE to design a variable lift either using a twist knob and gear or electric or sliding bolts with pins.
In an older, I think it was a Bayliner, I made a seat raising rig for a friend that was very cheap.
We had threads machined at the end of 4 SS rods to accept two nuts and a lock washer in between them - at the end of each rod. These rods were about 1/2" thick and about 8" long?
These were bolted to the four corners of the bottom of the seat base plate. I can't remember if we later reinforced it with 1/8" aluminum plates or not.
Two pieces of 1/8" aluminum plate about 20" long x 4" wide were placed (like runners) down the two sides of the fiberglass boat mold that supported the seat.
4 holes were drilled into these. The four "pins" that were bolted to the seat base slid up and down in those holes. My friend had 4 or so shims - different thicknesses of spruce from 2'' to 6" that he could place under the seat to elevate it.
It worked like a charm. It was solid, variable and cost less than 50 dollars for everything.
Personally, I like these kind of projects.
BTW just thought of it now but we could have drilled multiple hopes I the plates for fore and aft adjustment. Just lift, drop and shim.
But, if it was mine I'd look for something more exotic like an electric lift that worked with the sliders.....yes, retirement works.
I have painted a LOT of aluminum. If you decide to paint prep it first and I'd use a primer or the paint will not stick in some areas and orange peel in others. I used to spray the primer I was going to use on a rag and thoroughly wipe down the aluminum to get the surface milling residue off it. You won`t believe the black natural by products on aluminum. Wiping it with the SAME primer or paint you are going to use afterward prevents rejection as you are wiping it with what will follow..... if you get my drift. LOL
