Rinker 280 questions
first question
I didn't try the 110 power yet but noticed that all circuit breakers work on and off except the microwave breaker. It says off and when I try to flick it back to on it never locks in and goes back to off. I don't think that's normal but if I have to replace it where do I get the breaker from it's a 95 280
second question
hot water tank is located in the aft cabin and like all heaters it has a pressure relief valve.
it has a normal garden hose type screw on fitting. This fitting has nothing going to it.
in my mind it should have a hose going back to the bilge in case it does go off. This way it sprays hot water into the bilge and not inside the cabin ?
second question
As for the pressure relief on the hot water tank I agree and I did add a hose to redirect the spray should it every happen.
i will then test the breaker to see what the deal is.
cab someone explain to me what is the metal box with wires doing in there lol?
i don't know what it is maybe some sort of a manifold but looked oem
could be
shower sump has a separate pump inside then
normal bilge pump with a float is just for water getting in from outside or drain by the cabin door ?
