Hot water heater hose outlet back to engine corroded
Hi everyone,
Started engine and looked in engine compartment to find water flowing out of water heater. After further investigation I see the outlet for the hot water heater that connects to the hose going to engine has corroded. Why does water go from the engine to hot water heater? I was running water system while this happened. Turned water system off, tried engine again and water continued to pour. Shut engine off immediately. Guess I have to open up the hot water heater to fix. Any advise and help is appreciated.
Patrick
06 Rinker 270
06 Rinker 270
06 Rinker 270
So with the hoses going into the hot water heater that is used for when I'm not on shore power?
And if I use a double barbed fitting I can then use the engine without a worry.
Here are some photos, the hose coming out of the water heater was completely clogged.
06 Rinker 270
Eventually I will return the system back to the way it's suppose to be. Anyone replaced one of these? Probably call Attwood.
06 Rinker 270
I run in Boston / salt water. I actually ran for hours without knowing the hose had broken and was pumping 100 degree saltwater into my bilge and ultimately my cabin - flooding the mid cabin birth.
i had sea tow bring me in and we connect the intake and exit hoses like other readers suggested. Again this was a temporary fix with no hot water unless I was plugged in. Eventually we ordered a new Atwood tank, and reconnected everything. Sadly I still have a small drip from the fresh water/hot water red hose leaving the tank but can easily address that.
That at hot water tank has given me more problems than it's worth. Honestly why do I really need hot water in a boat for the issues the tank has given me.
Why did you have to replace the whole until? I don't think ill need hot water on the hook. I also dont like things to not work properly.
06 Rinker 270
I'm with Al re- servicing. I'm seeing way too much posting of corrosion on different boating parts and wondering if proper lay-up procedures are being conducted by some of the techs at marinas?
BTW the posting of re-painting of drives by @bella-vita was awesome. There are so many guys at the marina where used to store my boats for the winter, that got a few chips and dings and then ignored them year after year. pretty soon they had a massive and expensive mess on their hands. It's so important IMO to get right at chips and damage to drives and when you do prep and paint it like @bella-vita!
Also there is a nozzle on the tank with a tube running into the bilge. Will that drain it?
06 Rinker 270
Yes it will drain it - at least it did on my former 310 and 360s.... and the antifreeze and flushing should help. The crud in the water lines at marinas is another reason I used the cheap KDF in line carbon filter ($29)!
06 Rinker 270
Most of the time around those hoses aren't removed for winterizing. Pink stuff is just ran thru them while on muffs (I kinda like that word too Al). I had the same thing happen on my prior 310. Only reason I found it before hand is I was using the heater bypass for winterizing and bumped that hose and it came off. Got lucky! & let me tell you, that water heater in the 310 is a real pain to change.
@MT, this has nothing to do with the water at the marina. It has all to do with the water the boat is in.
06 Rinker 270
If you want to use the heating from the engine, then yes it will need replaced.
@Alswagg notes taken, thank you.
Times like this make me want to add a bilge pump alarm. Anyone do that?
06 Rinker 270
