stern anchor
brianluck
Member Posts: 174 ✭✭✭
what size stern anchor and line does everyone use? would you change it?
1994 300fv "General Madness"
the 14#'r up front does the job easily.. I like easy... :-)
I as of this posting have two 14# danforths.. one on the bow, the other in a box on my doorstep.. so, no more frustrating setting of line, and no more breaking free under current.. me digs that notion..
I've got a danforth that at one time was my main anchor for my 24'. It is either the 14# or an 18# (I can't remember, but I know it is bigger than a bow anchor for a mid 30' & seems very heavy) with 150' of line. I've had it hold thru some extreme storms with several boats rafted up with no problem.
I'd love to have a fortress, so I could take it apart after use and they are much lighter.
Do you think a 14lb Danforth is sufficient for a 2006 270? Says for boats up to 31ft but we all know the 270 is on the heavy side.
It would be greatly appreciated if anyone could explain how to set a stern anchor and attach to the boat. How much to pay out? Chain and rode or just rode? Attach to a cleat?
Thank you
06 Rinker 270
06 Rinker 270
Bella, you should be able to keep a bow anchor in without the stern. Just make sure you have at least a 7-1 rhode out.
Patrick, a 14# Danforth should be fine for what you are doing and can also act as an emergency anchor if need be. As far as how much to pay out, the more the better (both bow and stern). I use a 150' one off the back. Most of the time I use all of that length. You also need to note that the tidal change. If it's low tide when you set your anchors, you might want to leave a little slack. If you use 150' of rhode (bow and stern), then that should be able to adjust for the tide.
Some chain on the stern is good too. I have 8 or 10 feet of chain on mine. This lets it set on the bottom. Setting it, well, you can either swim with it (if at a beach area, not too bad - make sure to use a life jacket, also putting one on the anchor helps too) or you can use a dinghy to take it out and set it. & finally, I attach it to a cleat. I use an extension cord reel for my line.
If I were anchored aboard, I'm thinking I'd use single, and I'm thinking I'd have words with someone who came within a few combined boat lengths of me and anchored.....
Drew, I agree with 95% of what you said, but I have been at too many moorings to count and the bow anchored boats all swing together if a wind whips up without any drama. It works like a charm unless someone has not followed suit.
Stern anchoring when alone, without a genny in use, no problem. Off a beach, no problem - as long as you keep an eye on the water conditions.....a stern held down in rising waves is a viral video in the making!
P.S. Drew I do agree 100% that no one should be a couple of boat lengths from you - ever. But with a rode of 7:1 or better yet 8:1 a boat can have it's line lifted real fast in a wind gust and that's a lot of rode and chain if it gets pulled straight - the boats can move some distance - as long as everyone can swing together no drama!
It was fun recently watching the blue angels. Mid-way thru the day, the wind changed directions. You could tell those of us that had more rode out. Literally thousands of boats in a small area, all swinging pretty well & depths ranged from 5ft to 40ft. I had a little more swing than some of my neighbors, but it was ok (had more rode out). When I went to leave, my anchor was almost right under another boat. The look on their face when my bow was pulling anchor over their stern was priceless.
we don't have a very large tide change here, so not a huge deal with a lot of rhode out. I only use stern at the beach areas. & yes, you need to notice what others have done in the area and follow suit. Crazy that someone would not notice a boat using stern around others that aren't. Definitely agree that boat should pay.
John in a crowded place like that, Im guessing just using a bow anchor?
06 Rinker 270
MT, and DI- I've seen anchor under the fourth boat up from the boat anchored- that ain't a biggie... what IS a biggie, is nobody has business anchoring in open water less than twice the combined length of both boats away from me- it's just rude- you may as well raft up... and, it gives both parties ample time to recognize an abrupt change to the current/tide/wind...
I've never been a pirate before, but someone approaching that close would give cause to accept their friendship at least as long as it took to plunder their rum, no?
06 Rinker 270
yup....
I'm sure there is a point where it ceases to matter- like, maybe 100', but I've no interest in being that close to someone unless I know them or want to know them... I'd certainly, if they were there first and I wanted to anchor closer- ask them first.
of course, it's not like I hook on my 212.... on the beach I could often walk the full length of the beach thirty feet off the beach and not get wet...
It gets tricky at crowded events like 4th of July. Other captains don't always recognize that the big raftup won't swing. If they anchor too close, mayhem often ensues. BTDT.
Patrick, in a crowded place, yes typically just bow anchor.
rowboat, I know what you are saying about anchoring close and I agree. Only times when that is just not possible is big events going on for a just a few hours with tons of people. Take a look at my blue angels topic. There were literally thousands of boats in a small area. & yes, no big deal having an anchor under someone else's boat. Just funny they had no idea it was there as I pulled up. I had a large crew on the boat and I said watch the captain on the other boat. He was oblivious to me pulling up and had no thoughts my anchor would be under him (let alone didn't even think of moving or pulling his raft in floating behind him).
LaRea, you definitely bring up a good point about large raft ups. I've had some large ones on just my anchor so we could still swing. Typically when we use more than one anchor, we try to do it somewhere backing near land so we don't get in anyone's way when they swing. & yes, we always use a stern with morn than one bow anchor (I've had the ole' tangle of anchor lines & it's not fun).
It's also funny at times when I politely warn someone anchoring close that our raft up won't move. I mention they can just tie on as well
. Lots of times they do that (as rowboat mentioned). Just more rum coming in from another boat!
