Hot water heater hose outlet back to engine corroded
2»
    It's a galvanic problem?  How so?
    Patrick
    06 Rinker 270
    when you put 2 dissimilar metals together
  • SummerrentalSummerrental Member Posts: 35 ✭✭
    Hello all,.... I have the Seaward F-600 hot water heater that is about 10 years old now.  I also seem to have this problem as well (See pic).  Is the only way to correct this to either barb connect the hoses and bypass the heat exchanger? I assume it cannot be fixed and would need to be replaced if I wanted it to operate with the heat exchanger?  On a side-note...Is there any way to prevent this from happening?  I read that there may be a magnesium anode?  If so, where is it?
    Summerental,
    I just replaced the whole hot water heater on my boat, it was rusty and the element didn't work so I just got a new one, it was relatively cheap and easy fix.
    I was told the entire heater needs to be replaced and can not be fixed.  I currently am bypassing it but plan to fix someday.
    Patrick
    06 Rinker 270
    Thanks 06Rinker270 and NavyCTRC.. I will bypass for now.  I looked at it and it looks pretty simple to swap out and its easily accessible on my 2005 270.  Just seems like it should be preventable.   Thanks again!
    There are some new models that resist corrosion much better than the older constructions and are not much more expensive. Look around for sales at some of the big marine shippers like Defender Marine etc.
    MT hit the nail on the head, I got mine from Defender, and the new one is stainless steel so it shouldn't rust up and look crappy like the old one.  BTW: If you are a member of activecaptain.com, you get crazy discounts at defender!
    This spring, my hot water heater developed a small leak in the side of the compartment that the engine water flows through, its now disconected, but the other side works fine, replacement is in the future.
    If you have an older water heater you can put some Vaseline jelly on the connector at the tank and it will significantly reduce corrosion at that location.
  • aero3113aero3113 Member Posts: 9,991 ✭✭✭✭✭
    That's what I did when I installed my new water heater a couple of seasons ago.
