Fuel tank removal through the cabin, 2000 Fiesta Vee
Seazop
Member Posts: 23 ✭✭
As you can see by my attached photographs I have successfully removed my 100gal gas tank through the cabin. I did not have to remove the engine saving me lots of money. All I did was cut the firewall and rear bunk floor then I pulled the tank up and out through the cabin. I will now have a new tank built and reinstall the tank. I will leave the replacement of the wood and carpet to the professionals.
Saltwater between the tank and hull pitted the tank in four areas, each area was approximately 5inches round. The rubber collapsed under the 600lbs+ weight of the fuel causing the tank to sit on the hull causing water to be trapped. FYI, there is an overflow between the front bilge and the rear bilge where water can flow from the front cabin to the engine compartment.
I love the forum but I gotta stop clicking on the bad titles, lol. I'm becoming scared and paranoid the same events are gonna happen to me!. Good luck seazop!! Hopefully you'll be in the water soon.
Ditto. I loved my Rinkers but have suspended my search 'cause the bad stuff is scaring me! Maybe this fall I can find another boat.
The yard where I had the work done had a crane and the engine removal was pretty easy. Also, my oil pan had some corrosion and needed replacement too. The other needed work on the motor was much easier out of the boat due to the extremely cramped engine bay. However if your motor doesn't need work and a crane isn't available, then what you have done is apparently a good option on a FV270.
I would caution anyone looking to buy a salt/brackish water exposed express cruiser of any brand with a single aluminum belly fuel tank to be aware of the expense and trouble this kind of problem causes. My bilge is kept as bone dry as possible now.
Andy
Other than the problems with having a boat built around a gas tank that can fail prematurely, putting the fuel tank at the bottom of the bilge makes sense in regards to having the weight of the fuel act as ballast low down in the hull which gives the boat some more desirable handling characteristics I would assume.
Andy
