Engine sounds/runs great but very very slow acceleration
Little backstory...
Memorial day weekend ran the boat with 4 on board, 1/4 fuel, no water and little black water. We were loaded with all the necessities for a great day on the water. First time I noticed the boat was running sluggish. Engine sounded great and normal, but took me a long time to get going. I am still learning the fundaments of trimming drive and trim tabs but I now the difference between the 270s slow hull shot and being even slower than normal.
Month goes buy without using the boat and sitting in water. July 4th weekend I go out and she is even slower. This time I am by myself with a full tank of gas. I went out to play with trimming the drive and playing with trim tabs. Again, engine sounds great, RPMS seem normal, gps says I am going above 20 but speedometer says barely hitting 10 and boy it felt slow. Speedo normally works, worked Memorial weekend. Hull shot and felt like I was going no where.
I have new fuel filters and oil filters. New manifolds and elbows.
My thoughts are this and please tell me opinions. 1) Engine needs a tune up, not sure last time it had one. 2) Bent prop 3) I took off props last season and put them on correctly with correct alignment. Can they shift out of place? 4) Boat sat for a month but can there be that much build up that quickly to cause boat to be extremely sluggish? I plan to haul out next weekend to inspect hull and props.
Thanks everyone for reading and opinions. Been a great season so far cant wait to continue.
Patrick
06 Rinker 270
06 Rinker 270
I am thinking something must be lodged in props or wrapped around. Its crazy, I slowly move throttle forward when accelerate and engine sounds and acts as always, but I go nowhere(I mean I do move but nothing like in the past). As if the props just are not spinning correctly.
There is no vibration that I am noticing.
Tune up - spark plugs, wires, all hoses(going to fuel line as well), will change oil and filter just to do it. What else?
06 Rinker 270
06 Rinker 270
Another note...I was out practicing trimming and I noticed things did start to get a little better but never to optimum performance.
06 Rinker 270
06 Rinker 270
Bottom Growth, period. I can bet on this one big time!
06 Rinker 270
@06Rinker270 , put it this way, my boat was in the water for the past 17 days. 10 of them was a trip we did, so the boat moved every few days. The next 7 it sat in the water for a couple repairs to get looked at (heck, even got moved by a towboat accidently - a totally different story). Point is, after that time, I noticed a big difference in performance. The difference was about 4k in RPM - I had to do 4100 for what I can normally get a 3700. When I got back to my lift, I cleaned the bottom (it is bottom painted) and noticed there was definitely a good coating on the bottom.
A few years ago my boat sat for 3 weeks without using it. I took it for a ride and the boat would barely move. I was like WTF is wrong. Thought I had a major problem. Took it to my marine mechanic (who I bought it from and store for the winter) and he hauled it out. I had a complete bottom paint failure. My boat was loaded with barnacles which we never get at my yacht club because of the strong current. Point is it only took 3 weeks for that to happen. Maybe you need to go in the water and take a look at the bottom.
I hope that is the issue @Dream_Inn. I could also have the wrong bottom paint for my area as boats sit way longer and I dont hear them complaining. @raybo3 what you are describing sounds exactly like what I am dealing with. I am going to use one of my marina boat lifts this weekend to check it out. I normally dont allow the boat to sit that long but I had this thing they call a wedding and took away from all the boating fun. Back to normalcy, this time with an admiral.
Thanks for the help everyone. Ill post with an update after the weekend. Its going to be a hot one.
06 Rinker 270
A couple slipped next to us do a month long trip to 1 marina every year to get out of Colonial Beach. I think next year I am going to do that, and make it to Annapolis. Such a wonderful place to be a boater.
06 Rinker 270
06 Rinker 270
And -- jeez, are your anodes are almost gone already? That's unsat.
I thought so also about the anodes. Tech put them on. Why is there so much fouling on the anodes? Also there was a TON of barnacles under one of my tabs and on the white stripe around the drive where it's not painted.
Drive was painted lasted year with Trilux drive paint.
Beaides power wash what is the best way to get them off? Those SOBs tore my hands up.
06 Rinker 270
