@Cableguy Greg yea just learned that this morning from ITC. I can't tell if I have the blue lights or the white lights. I'll see what yours looks like and judge if it's the same.
Having issues with my anchor light. The lighted worked but I noticed the connectors have all corroded so I pulled them apart and used heat shrink connectors. I connected red to grey and black to black. Now I have no light. Did I do something wrong?
It is an LED bulb and although I am not sure which is the correct way, I have tried both as I have had that issue when I switched to LED.
My main failure here, when everything corroded I was in a hurry and pulled apart and put electrical tape over it until I could attend to the issue, failing to note the correct orientation.
If it doesn’t light, just switch the two wires and see if that works... it won’t hurt anything. I have found that the colors of wires in the “boat world” mean nothing in relation to polarity.
06 Rinker 270
http://denledxe.com/
06 Rinker 270
06 Rinker 270
I have red to grey, black to black. Correct?
06 Rinker 270
Silly question, but having heat shrink rather than insulated connectors shouldn't make a difference correct?
06 Rinker 270
