Hisham Kinani
HishamKinani
Member Posts: 23 ✭✭
I bought a 342 Fiesta Vee (2005) , how can I download its owners manual , as I am facing difficulties getting to be familiar withe my boat ie: how can I get access to the fuel,water,waist tanks down in the Hull, also the bilge pump and other equipment down in the Hull !!! And many other issues re benefiting from my boats facilities ...
Best Answers
Liberty44140 Member Posts: 4,373 ✭✭✭✭✭Look around at @DanD2 posts on this site. He posted a video of how to get to fuel, water and waste tanks through the aft cabin. The only way to get to the tanks is through the aft cabin. Also search my posts, I posted pictures of how to add access panels in the aft cabin rear storage area to check the level of the waste and water tanks. Lots of 342 info out there on this site, you just have to do a little searching. Congrats on your new boat!07' Cruisers 390 (Previous Rinker's: 06' 342EC & 01' 310FV)
randy56 Member Posts: 4,083 ✭✭✭✭✭On the discussion just below this one, Winterize water and waste tanks, you will see a post by DanD2, click on his user name it will take you to his profile. Then click on his discussions.Boat Name :
Black_Diamond Member Posts: 5,439 ✭✭✭✭✭There really is no 'owners manual' per se. It is a collection of the manuals from the various equipment suppliers: engines, drives, generator, AC/heat etc. most all can be found on line or on here too.
The fuel, water and waste tanks are not easily visible. The water/waste tanks can be seen a few ways, a lot of people take the side walls down from the storage area behind the mirror in the aft cabin.
PC BYC, Holland, MI -
DanD2 Member Posts: 848 ✭✭✭Good luck with your 342......You'll like it, is an awesome boat. First link I posted has some info for you. The second link is my youtube video on getting access to the tanks.
I've torn apart just about every aspect of my 342 and have done a bunch of MODs. Check out the Rinker Custom Projects Thread. Some of that info I've learned from here, (this is a GREAT site BTW) and some of it on my own. Feel free to ask, I'll share all that I know.
http://rinkerboats.vanillaforums.com/discussion/4861/2003-342-port-fuel-tank-leak/p1
https://www.youtube.com/watch?v=W_q8jW_EdZ0
No longer a boat owner.....previous boat - 2005 Rinker Fiesta Vee 342 -
DanD2 Member Posts: 848 ✭✭✭@HishamKinani, this is a thread that EVERYONE can see and only member can respond so your on the right track. Anything posted through someone's profile is private message to the individual that you are writing toNo longer a boat owner.....previous boat - 2005 Rinker Fiesta Vee 342
randy56 Member Posts: 4,083 ✭✭✭✭✭@HishamKinani, I had all the same questions when joining this forum. I wish there was a chapter on how to use it, but have it figured out now. We have 3 moderators. So if you get out of line they will have you arrested. LOL Just keep doing what your doing you figure it out.Boat Name :
I keep a working list derived from experience etc that works pretty well for me. It follows below. Some of the stuff was done last week. When I get the boat back and the bill, I will check those things off and move them to the "done" list.
Salt Shaker + Regular boat maintenance:
Look into Rad power bikes $1500.00 ea 08/24/2016
Grease the lifts each September. 06/10/2016 Done 07/06/2016
Change all impellers annually (3) 04/02/2016
Clean filter for air conditioner each 6 months. Done 04/11/2016
Change gear lube every 50 hours, 100 hours max per Al Swagg 04/18/2016
Exercise (identify them and list) seacocks every 6 months 08/22/2016
Replace zincs on boat tabs and engines next service 03/20/2016
Service batteries in engine room 05/03/2016
Service engines and drives 04/12/2016
Engine alarm sounds shortly after start up and stops once we are under way. 05/03/2016
Shower sump is slow 05/03/2016
Replace Faria tachs with something decent. 06/12/2016
Risers are showing some corrosion at the gaskets 05/03/2016
Check fuel valves and hoses for integrity 04/16/2016
Fix water flow into icemaker 05/03/2016
Engines had a “running rough” period last time out. 06/14/2016
Trim tabs went inop on most recent trip 06/14/2016
Repaint bottom 07/14/2016
Look into Westerbeake Generator to replace existing one 09/23/2016
Look into “drive showers” for the Salt Shaker 03/26/2016
Figure out hailer and put on a menu button. 03/26/2016
Get longer cord for ham radio speaker aboard Salt Shaker 03/26/2016
Replace batteries in all portable equipment annually:
Remote for Alpine radio 04/12/2016 Last done 04/12/2016
Lithium batteries currently in SPOT expire 03 of2023 04/15/2016
Charge all rechargeable batteries for all portable equipment semi annually:
Portable power drill motor 04/12/2016
Batteries and service for ACR PLB 350 ELT reqd 12 of 2015 Should also re register 04/15/2016
Design build and install 20 meter Windom for Salt Shaker 04/12/2016
Repair deck in cabin 03/20/2016 Check with Dan the Detail Man for name.
Repair blemish on starboard side of hull 03/20/2016 Check with Dan the Detail Man for name
Service CO detector on recommended schedule TBD 04/17/2016
Trim Dri Dek pieces to fit in cockpit side compartment 04/17/2016
Service fire extinguishers 04/18/2016
Check dates on Flares 04/18/2016
Drain for sink in head is slow flow 05/03/2016
Procure some double banana plugs for antenna connections 06/11/2016
Yeah it should be the same or at least VERY close, I believe the only difference in mine is that it came with a grey water tank. Having "the basement" is actually helpful in that you can put viewing panels to see your water and waste tank levels should the gages go bad.
https://rinkerboats.vanillaforums.com/discussion/5826/342-waste-water-tank-view#latest
I re-ran the TV coax when I moved the TV to a spot over the mid-berth. I also ran an HDMI cable from a blu-ray mounted in the old CD changer location. I ended up running it under the windows, tucked in close to the outside of the ledge, below the curtains. I had to snake some wires from the cockpit into the cabin. I was able to peek from the opening for the window above the dinette, toward the aft, back and saw an opening. I took off the sub-woofer in the cockpit which lit up the area. it was easy the fish a wire through the opening there.
the red markings? are they right under your user name a picture of a globe ? click on that globe.
And again should I reply here as am doing now or should I reply in comment in my profile or yours !!!!!!!! I am very sorry for inconvenience I am causing you but I am lost in the site ...
Yes reply here unless it is a personal message. (PM) I will sent you one, for a test.
