290 FV no forward or reverse
was out yesterday everything great after anchoring and swimming started both engines, put both in forward and was puttering along away from swimming area, then decided to get up on plane. Immediately high rpms on starboard engine but no movement. Idled back down and tried again, then in reverse- same result: plenty of engine rpm, but no movement of starboard engine. During this time while trying in forward or reverse and whirling sound. No grinding or high pitch whining, but like a loud (well loud enough to hear over engines) whirling. Had to come back to dock on port engine only.
Inspected shift cables to engine- everything functioning visually. Of course boat is in water and I can't really see the ourselves even in up position due to swim platform.
Thought maybe i threw a prop or the hub, but does a 2003 mercruiser 5.0 MPI bravos have hubs in the props. They are dual props and counter rotating.
Didnt inspect behind engine inside where shaft comes out, but there was no biting rubber smell or anything like that.
Any thoughts?
Any thoughts?
i had one drive blow on me mid cruise
and one spun hub on the prop.
thats was an alpha drive
you probably have bravo3
If it is the coupler, Mercury makes a HD (Heavy Duty) replacement/upgrade, worth the few dollars considering all the work to get to it.
If you decide to check as rasbury suggests, please be careful when in the engine compartment while engines are running. The drive does not have to be in gear. If the coupler is good the input shaft to the drive should rotate all the time if the engine is running.>
So so that means boat has to come out of the water. What fun! Lol.
Question: I've read some say you have to pull engine; others say you have to pull outdrive. I think some one said both. Which is it? Engine, outdrive, or please don't say both. I'd think it could be replaced just by pulling outdrive off?
thanks for everyone's advice.
not a happy day I guarantee you.
coupler needs engine shift or lift to get to it
who knows if twins alignment was good or bad or wore wore out.
next year same thing to other
