Outdrive leak
I'm getting out drive Oil in the bilge about 2 ounces a day I can see oil at the transom but I can't figure out where it's coming from so I pulled out drive the Bellows was completely full of oil no water everything looks good nothing more out but I can't figure out where the oil is coming from . Anybody got any ideas in the hose looks good the reservoir looks good . Here are some pictures of my homemade stand to hold out drive while I'm servicing It.
number 28
The blown oil seal is where the shaft goes into the upper drive. Just replacing the seal rarely fixes the problem as shaft wear and/or carrier bearing wear will just make it keep leaking.
2x Flappers
4x Connector boots (two different part numbers per side)
16x clamps (always replace!)
The job is pretty straight forward to do. the parts are not cheap. The risers do not need to come off.
Good luck.
Next I've got to tackle the flappers not really looking forward to this being that I'm going to have to get in the engine compartment and I'm 6 foot four and 225 pounds
