Battery switch position
Mercury2005
Member Posts: 141 ✭✭
Need clarification on using the three position battery switch. I tried to open the engine hatch by putting the switch on 'bat 1', no function, tried 'bat 2', no function, tried 'start' and it worked. I did not have the key on when using bat 1 or bat 2 or switch. Should the hatch operate no matter what battery is selected?
Also need help with starting procedure.
I assume putting the battery switch in the 'start' position is obviously for starting only, and, after starting I need to move the battery switch to either bat 1 or bat 2. Is that correct?
Additionally, can I assume that both batteries get charged no matter which position is selected?
Thanks to all in advance for help.
The hatch should open on any switch position...Sounds like your batteries don't have enough charge to work the hatch.
Yes both batteries should charge regardless of switch position.
Here is a pretty good explanation of the wiring and purpose.
http://bluewatermarinesvc.com/html/bat_isolator.html
I'm a little confused. You're switch says "Start, 1, 2 and OFF"?
I'm going to guess that Start puts the batteries on both - so both in parallel to start the engine.
Bat 1 would then start from Bat 1 and Bat 2 would start from Bat 2.
You need to check the wiring to confirm.
If you have an alternator to charge the batteries, and if it is charging both batteries (you need to confirm), then there should be an isolator. This will prevent one battery from "charging" up the other battery, and ensures that only the alternator charges a battery, when it needs to be charged.
For that same reason, you should NEVER change the battery switch setting while the boat is running. Reason is as you change the battery switch, there's a surge in power, and that can destroy the isolator. Destroying the isolator will prevent your batteries from getting charged.
As for the helm not operating - there could only be 2 reasons:
- batteries are dead, or
- power is disconnected (so check for a breaker that has tripped under the helm, or a switch somewhere).
I'm hoping it isn't your batteries that are dead due to switch usage while engine was operating ...
In terms of natural usage of switch, pick one battery you want on your engine (which should be a crank battery, high amps), and choose another that you want on your house (for lights, TV, etc) that should be a deep cycle.
Leave the switch on the battery you want to start your engine. You do not need to switch it while the engine is running. If anything, you could switch it off, after you've shut the engine down, and then switch it back before you start your engine again.
I looked at the panel again and it says 'emergency start', sorry for the misidentification. Attached is a pic. I first put the bat switch in bat 1 and tried to operate the hatch, no go, same with bat 2, no go, only worked in emergency start position. Don't know condition of batts, just bought the boat and got it home to Maryland. Doing a little work on it and needed to open the hatch. With the switch in ES position, the hatch opened with the dash switch.
I will do more checking when at the boat this week. Where is the isolated located? It could be the previous owner/operator moved the switch once running. I will probably replace the isolator just to be sure.
Thanks for the info.
This not our first, but is our first boat with all the amenities, so we have a lot of systems to learn.
This what one looks like, should be mounted on the firewall, not to far from the battrie's
https://cdn3.bigcommerce.com/s-6rtev5owwo/products/225111/images/109968/mar-p15-30_lg__28321.1469113302.1280.1280.jpg?c=2
I keep the switch on on "emergency start" when charging as if I keep it on #1 or #2, one battery dies. I have one battery charger and its new. I wonder if I have an isolator or tech wired new charger wrong? Been dealing with battery charging issues for a while now. I will look this weekend.
06 Rinker 270
