Windless For a 2007 Rinker 280 Express
2»
  • TazTaz Member Posts: 62 ✭✭
    Cheers, I have just bought one, £650 with a 10kg anchor thrown in, not sure how that compares over in the States ?
  • 282CaptivaBigRed282CaptivaBigRed Member Posts: 2
    I thought I would jump in here as this seems to be a hotbed for windlass info. I have a 2005 Captiva 280 Bow rider, it has a CB at the main power panel for a windlass, 70amp. Here are my questions:
    1. Based on this thread should I expect to have 4ga red/black wires run from the main panel near the transom to the helm and 4ga run from the helm to the bow near the anchor locker?
    2. If so based on the picture it looks like I will need a isolator and up/down switch at the helm and run switch wires only from the helm to the windlass to control the anchor up/down?
    3. I am running down here in the bays and near shore of the Florida gulf coast, off of Panama City Beach I have a 14lb Delta anchor on a 15ft 1/4 ISO G4 chain spliced to a 3 strand 1/2inch rope (did the splice myself after watching some you tube videos, hope it holds) as it is a bow rider no overnight mooring or sleeping, bottom is mostly sand, some weeds, so the question is what pulling power windlass should I be looking for?
    Thanks in advance
  • IanIan Member Posts: 2,907 ✭✭✭✭
    If I recal when I was looking at replacement the Lewmar site had some selector charts. I also called or emailed them and they were very helpful in answering questions and clarifying things.
    Guys I have found the cables going to the anchor locker, where is the best place to mount the relay ?
  • Cableguy GregCableguy Greg Member Posts: 5,039 ✭✭✭✭✭
    Glad you found them. Did you find them at the helm as well?
    The other end should be at the help where the switch and breaker is located so that would be the place to put the relay/contactor.
  • tazataza Member Posts: 64 ✭✭
    Well it took a while,and help from Rob at Rinker we have found the cables
    so thanks everyone
    Taza :
