Kohler Genny
raybo3
Administrator Posts: 5,460 admin
I hate my genny........ Freaking thing never wants to run. Why are they so sensitive??????? Why does it take so little for them not to run. I guess I am just venting.................Sorry.....
2002 342 Fiesta Vee PC Point Of Pines YC Revere MA. popyc.org raybo3@live.com
In my case it is always by the book. No load at start up etc. Also I run it periodically for about 5 minutes. Progressively turning on the stove and air conditioner to load it in the process. This maintenance activity is more sporadic than it should be. Today would be a good day, wouldn't it. )
Tony
Salt Shaker 342
Ray
2006 390
Previous 2000 340
Today was the day. After a nice hour and a half ride out to the Skyway Bridge and back, got the engines flushed so the next chore was to exercise the generator. Started up on try number 3. Awesome! This was the first time I ran it in its new environment. It is now mounted on several squares of dry deck. It would have been my luck that this could have created a resonance induced vibration. But not so. It ran just fine and was very happy.
Tony
Salt Shaker 342
I guess I had a generator issue a few months back. Lesson learned--do not tie the kayak to the side to the side of the boat with the generator exhaust. And if you do that, do not run the generator. I violated both rules and I found a kayak full of water we had to pump out. Laugh, yes. It sure was funny.
Tony
Salt Shaker 342
@Dream_Inn: I do not have a display with error codes, so it is like hunting blind, it has been this way since day one when it was new. I bet Kohler had a few thousand dollars into warranty repairs, of which none worked. It does not matter the load, usually once it shuts off it will crank and start for a second or two then shut off again. I keep wondering if it is overheating, but I get plenty of water coming through the exhaust (no steam). Strainer is clean. Plugs are new. It's almost like it runs out of fuel..I thought I had that problem licked when I hard wired the fuel pump (bad connector).
I'm going to order a rebuild kit for the electric choke, replace the fuel solonoid as another attempt. Might try to rig a temperature sensor. Maybe even just replace the over temp sensor for the heck of it.
I did run across a thread where if the ground is not attached to the ground lug on the engine, you can get voltage issues to the electric choke. I guess some have the ground to other locations. I'm pretty good with engines but this one has me scratching my head.
2. Remove outbound coolant hose going to vented loop at vented loop.
3. Attach water hose using homemade adapter to coolant hose removed in step 2. Be certain to connect to correct coolant hose segment as using the wrong one can result in water ingestion into the cylinders.
4. Turn on water while you try to "catch" everything coming out of the hole in the exchanger created by performing step 1.
5. Change clothes as step 4 provides free shower.
propane or NG burns mucho safer than gasoline, with very little CM.. it would be safer to use.. it also burns cleaner for the engine, doesn't stale, and doesn't gum- the engine would last a lot longer... it would be an effort to pull out and convert, but it would work better and last longer, and be a ton safer..
yeah, running lines to the engine compartment where a bottle bracket could be fashioned would be a pain, and filling them would, too.. I would guess most your marina's have that blue rhino exchange cage, no?
it's just a thought, for what it's worth.. the reason I bring it up is after reading BD's five hours in the hold with his over labor day weekend- one thing indisputable about LP or NG: engines that run them last a LOT longer and are easier to maintain..
LP is safe- it's actually a non-greenhouse, and the additive smells enough that you'd discover it pretty quick..
but, I dunno if it's worth the effort or having to built strategy and logistics for..
