Koehler 5e new unfamiliar problem
so about to head out for the weekend and the genny decides to give me hassles. I was down 2 days ago to commission it for the season and it ran well for the most part. I have consistently had issues where the throttle seems to hunt until it's warmed up and then it's fine. cleaned the carbs last season, air filter etc and it still hunts/revs at startup then evens out. But otherwise runs fine. So the other day I changed the plugs, fuel filter, anode and fired her up. It ran great under load for 40 minutes or so until I shut it down. Today I decided to run it before going out on anchor and it ran for about 2 minutes then it shut down. I went to inspect and it all seemed in order. Oil was at full line, coolant was good. I then fired up again and it ran for maybe 20 seconds and would shut down. Seeing I hadn't changed the impeller I decided to eliminate that as the issue. I changed it as it was a year old And in need of a change. When I took it out 5 of the vain ends were gone so I backflushed the exchanger. I put in the new impeller and had great water flow now but it would shut down in 10-20 seconds every time I started it. Any ideas why this thing isn't running even long enough to get it up to temp.
Edit: I edited my original post from some mistypes on run times today.
Post edited by craigswardmtb on
Word of caution, make 100% sure you run the water back from the correct tube or you will fill the engine with water!!!! The tube with the loop/anti-siphon valve is the one, just use the correct side of the loop.
BTW: Yes the impeller is an annual change part IMO.
Thoughts?
I had, amongst other things, a bad electrical connection to the fuel pump. Just flakey enough to work sometimes others for seconds or a few min. Basically would run out of gas. I hard wired the connection.
So far I have changed plugs, both fuel filters, impeller, flushed exchanger, adjusted echoke heater, cleaned lubed choke linkage(moves freely), replaced input and voltage fuses, new Antidiesel solenoid. It ran fine for 30 minutes the first time this season and has exhibited this issue ever since.
Has anyone had issues with sensors going bad and throwing a false led4 (shutdown). Maybe @Black_Diamond
It is P/N GM30263 (pressure switch) http://www.partsfortechs.com/asapcart/gm30263-switch-pressure-assembly-kohler-p-1315.html
I've seen them clog pretty easy. You can bypass it to check (I can't remember if short or open bypasses it)
