2004 270 FV stove top wiring?
J3ff
Member Posts: 4,060 ✭✭✭✭✭
Ditched the alcohol stove/burner combo for just a sleek looking glass burner:
So far this year I've been fighting problem after problem....and of course when I flip the breaker and turn it on, it doesn't work!!
This is how the old one was wired:
The new one only has three wires, not six.. so I figured maybe the new one just didn't require dual connections..
I was wrong of course....
So I guess I should have tested it before going through all this hassle, but I installed a junction box, capped off the lines I thought I didn't need and then wired up the remaining three wires to the one on the burner..
Obviously the wiring must need both sets of wires hooked up to the input to the burner.. does anyone know how to go about doing that when it looks like the power wires will need to be combined inside the junction box, vs right on the burner (because there doesn't appear to be any place to put two sets of wires on the new burner)..
Old Cooktop: https://www.amazon.com/exec/obidos/ASIN/B00A9WF0MM/banbcwriser-20
New cooktop: https://www.amazon.com/Kenyon-B41605-Caribbean-Cooktop-120-volt/dp/B0011YNILC
So the question is where do I go from here?
Thank you for any help.
Post edited by J3ff on
120 will be a hot a nuetral and a ground.
I can't see the pics you tried to post
Only reason I can think of for 6 wires on old cooktop would be if the element was a dual coil, each with it's own feeds, and three for the new makes sense to me, one hot, one neutral and one ground. But those pics might help.
Old one = 240
New one = 120
Didn't mess with the breakers.. do I need to swap a breaker too maybe?
Edit: - The more I look at the first pic, the more I think that's what they did, they ran the 3 wires to the cooktop, and then junctioned off that to go on and feed something else.
You say the fridge is plugged into a receptacle, but no breaker...just one for stove. Trace the wire from the fridge receptacle and see if it doesn't head up towards the cooktop area. I'm betting that's how they fed it. And you can't tell by unplugging the fridge from AC, because it'll just flip over and run on DC.
I can test out the fridge theory when I get back to the boat pretty easily... will just kill the DC power and see if it turns on while hooked up to AC..
Didn't realize that the fridge was wired into the same breaker just as you all said.. Fixed the wires and we're all set!
Will, does yours light up anything over the word "HOT" ? Mine doesn't and it's def. hot!!
