Took out cooler opening in my 270.....EDIT pics added
Wow, I can't believe how much room is in behind there, its going to be great once I get a door on it. What a waste of unused space.
Post edited by BellevilleMXZ on
great project, looks good!
i just store it in that space. i run the genny on the swim platform when in use
Door not installed yet, I'll get pics forsure
2. Where'd you get the carpet from and how much?!
3. What were the exact measurements you used? completely want to copy you.
Just a good clean with spray 9.....I'm a little fussy....lol
Snap in carpets.....just laid in there today, gotta get snaps on it. 1250.....pricey but I don't have the spare time to cut/sew/screw around. This way get the color we want too. Feels great on the feet, and color shouldnt show dirt.
The door? opening is 21 by 21 on mine, you have to trim the corners though, as the orig is quite rounded, .......I also had to trim one side a bit......opening wasn't perfect. Used a dremel with a tile bit, and kept vac. right close to keep mess to a minimum. Got it from boat outfitters.....one of best mods I did
That is their "white/white" color right? Do you know what they are talking about with a bulb seal?
Its seagrass #7 (MW#7) -----bulb seal, probably the binding?
Order Number: S637
R pattern
2005 Rinker 270 FV
Ill.look at order tonight to see what color it was
Color: Arctic White
Hinges: Height - Hinging Right
Lock Type: SS Non Locking
Bulb Seal: No Seal
Vented Louvers: No Louvers
Height: 21"
Width: 21"
MeasurementType: Cutout
Same problem
