Importance of Anchor/Chain/Rode Inspection
Willhound
Member Posts: 4,236 ✭✭✭✭✭
Recent posts on windlass issues, and noticing that the last few times I raised anchor my chain was binding in the gypsy a bit, I thought it a good idea to pull everything out of the locker and take a look. While berthed nose in I dropped the anchor to the dock and once past the 15 foot chain was able to lift the control arm and start pulling the rope up out of the locker. Wow!......what a mess. Mud, dead sea creatures, weeds and general crud. Worst part was realizing that the rope was so badly twisted up that it was self-knotting and I would have never been able to drop anchor in deeper water if needed in a hurry. It took about 25 trips down below deck to reach in the locker and un-twist, un-knot and un-tangle the rope and then back topside to keep pulling it all through.
When finally all out I was able to hose everything off, wipe it down and by repeatedly running the rope out while pulling out the twists I was able to get it all straightened out. I was also able to see that the rope to chain braid was worn badly and needs to be re-braided before I lose an anchor and chain. Generally the rope itself was in good condition once the mud and mould was wiped off it.
This is now going to be a semi-annual inspection/maintenance point for me.
When was the last time you had it all out?
@Willhound - one reason the investment of foot switches was one to make last year. So much easier with the Admiral at the helm working position and me at the bow dropping, placement, locking the clutch and tying off.
These markers stick out a bit from the rode, so you can see them better. Cheap, easy to install, durable, won't tangle.
My most important rode marker is the fact that I have 60 feet of chain. When I stop hearing the rattle of the chain, I know I have 60 feet out.
These are good for 3 strand, I have 8 plait, may not be as compatible. I may go for colored whipping twine instead.
Shopping around for a fid so I can resplice my rope to chain. When I do I'll Mark off the rope too.
I spray painted orange marks every 10' on the rope portion. Works decen.
Any idea what caused it so I don't do it again? I did have some pretty bad twists to contend with when I pulled the rode out, I suspect it was likely twisted and caught on the gypsy.
The two snags are about two feet apart with the second pic being a closer shot of the worst one.
https://www.marineoutfitters.ca/index.cfm?product=44730805&code=Titan 10525082
https://www.pocomarine.com/shop/titan-anchor-rode-150′-58″-8-strand-plaited-nylon-rope-50′-516″-g4-windlass-chain/
This is supposed to fit the RC0860 gypsy which I believe l have. It was the most common I beleive. Can't get to boat for a few weeks, does anybody know if that was the case for a 2000 era FV270?
